AVR-Chat
interupt priority
interupt priority
2013-10-11 by Mehdi Ghassemi
Hi dear
if my program is executed TIMER0 service routine and TIMER1 OVF interupt occurs what is happening?
thanks for your reply
Re: [AVR-Chat] interupt priority
2013-10-11 by Jim Wagner
Timer1OVF does not execute until TIMER0 isr ends and code execution has returned to non-isr code.
Jim Wagner
Oregon Research Electronics
To: AVR-Chat@yahoogroups.com
Sent: Friday, October 11, 2013 7:23:33 AM
Subject: [AVR-Chat] interupt priority
Hi dear
hi jim
thanks for your attention
have we a way that the timer1 OVF in this problem is executed because the time execution TIM0 is long (200us)?
thanks a lot
On Fri, 10/11/13, Jim Wagner <wagnejam99@comcast.net> wrote:
 Subject: Re: [AVR-Chat] interupt priority
 Date: Friday, October 11, 2013, 7:47 AM
       Timer1OVF
 Jim Wagner
 "Mehdi Ghassemi" <m_gh77@yahoo.com>
 Hi dear
RE: Re: [AVR-Chat] interupt priority
2013-10-11 by tom@outsidetrains.com
PHA+WWVzLiBHZW5lcmFsbHksIHlvdSB3YW50IHRvIGtlZXAgaW50ZXJydXB0IGNvZGUgc2hvcnQg YW5kIGF2b2lkIGRvaW5nIDIwMHVzIGpvYnMgaW5zaWRlIHRoZSBpbnRlcnJ1cHQgcm91dGluZS4g JnF1b3Q7QnV0IHRoaXMgd2hvbGUgOGsgb2YgY29kZSBpcyBhbGwgYSBjcml0aWNhbCBzZWN0aW9u ISZxdW90OyAtLSBZb3UmIzM5O2xsIGp1c3QgaGF2ZSB0byBzcGxpdCBpdCB1cC4mbmJzcDs8L3A+ PHA+PGJyPjwvcD48cCBzdHlsZT0iY29sb3I6cmdiKDAsIDAsIDApO2ZvbnQtc2l6ZToxM3B4O2Jh Y2tncm91bmQtY29sb3I6dHJhbnNwYXJlbnQ7Zm9udC1zdHlsZTpub3JtYWw7Ij5UaGUgdXN1YWwg c3RyYXRlZ3kgaXMgdG8gaGF2ZSB0aGUgaW50ZXJydXB0IHJvdXRpbmUgc2V0IGEgZmxhZyBvciBi aXQgb3Igc29tZXRoaW5nIGFuZCBoYXZlIHRoZSBtYWluIHJvdXRpbmUgd2F0Y2ggZm9yIGl0Ljwv cD4gPGRpdiBjbGFzcz0ieWdyb3Vwcy1xdW90ZWQiPjxicj48YnI+LS0tSW4gQVZSLUNoYXRAeWFo b29ncm91cHMuY29tLCAmbHQ7YXZyLWNoYXRAeWFob29ncm91cHMuY29tJmd0OyB3cm90ZTo8YnI+ PGJyPjxkaXYgaWQ9InlncnBzLXlpdi01NzE5ODg2NDUiPmhpIGppbTxicj4KdGhhbmtzIGZvciB5 b3VyIGF0dGVudGlvbjxicj4KaGF2ZSB3ZSBhIHdheSB0aGF0IHRoZSB0aW1lcjEgT1ZGIGluIHRo aXMgcHJvYmxlbSBpcyBleGVjdXRlZCBiZWNhdXNlIHRoZSB0aW1lIGV4ZWN1dGlvbiBUSU0wIGlz IGxvbmcgKDIwMHVzKT88YnI+CnRoYW5rcyBhIGxvdDxicj4KLS0tLS0tLS0tLS0tLS0tLS0tLS0t LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS08YnI+CjxibG9ja3F1b3RlPjxzcGFuIGNsYXNzPSIiPiBP biBGcmksIDEwLzExLzEzLCBKaW0gV2FnbmVyICZsdDs8YSByZWw9Im5vZm9sbG93IiB0YXJnZXQ9 Il9ibGFuayIgaHJlZj0ibWFpbHRvOndhZ25lamFtOTlALi4uIj53YWduZWphbTk5QC4uLjwvYT4m Z3Q7IHdyb3RlOjxicj4KPGJyPgogU3ViamVjdDogUmU6IFtBVlItQ2hhdF0gaW50ZXJ1cHQgcHJp b3JpdHk8YnI+CiBUbzogPGEgcmVsPSJub2ZvbGxvdyIgdGFyZ2V0PSJfYmxhbmsiIGhyZWY9Im1h aWx0bzpBVlItQ2hhdEB5YWhvb2dyb3Vwcy5jb20iPkFWUi1DaGF0QHlhaG9vZ3JvdXBzLmNvbTwv YT48YnI+CiBEYXRlOiBGcmlkYXksIE9jdG9iZXIgMTEsIDIwMTMsIDc6NDcgQU08YnI+CiA8YnI+ CiA8YnI+CiA8YnI+CiA8YnI+CiA8YnI+CiA8YnI+CiA8YnI+CiA8YnI+CiA8YnI+CiA8YnI+CiA8 YnI+CiA8YnI+CiA8YnI+CiA8YnI+CiA8YnI+CiA8YnI+CiAmbmJzcDs8YnI+CiA8YnI+CiA8YnI+ CiA8YnI+CiAgIDxicj4KIDxicj4KIDxicj4KICAgICA8YnI+CiAgICAgICA8YnI+CiAgICAgICA8 YnI+CiAgICAgICBUaW1lcjFPVkY8YnI+CiBkb2VzIG5vdCBleGVjdXRlIHVudGlsIFRJTUVSMCBp c3IgZW5kcyBhbmQgY29kZSBleGVjdXRpb248YnI+CiBoYXMgcmV0dXJuZWQgdG8gbm9uLWlzciBj b2RlLjxicj4KICZuYnNwOzxicj4KIEppbSBXYWduZXI8YnI+CiBPcmVnb24gUmVzZWFyY2ggRWxl Y3Ryb25pY3M8YnI+CiA8YnI+CiA8YnI+CiA8YnI+CiA8YnI+CiBGcm9tOjxicj4KICZxdW90O01l aGRpIEdoYXNzZW1pJnF1b3Q7ICZsdDs8YSByZWw9Im5vZm9sbG93IiB0YXJnZXQ9Il9ibGFuayIg aHJlZj0ibWFpbHRvOm1fZ2g3N0AuLi4iPm1fZ2g3N0AuLi48L2E+Jmd0Ozxicj4KIFRvOiA8YSBy ZWw9Im5vZm9sbG93IiB0YXJnZXQ9Il9ibGFuayIgaHJlZj0ibWFpbHRvOkFWUi1DaGF0QHlhaG9v Z3JvdXBzLmNvbSI+QVZSLUNoYXRAeWFob29ncm91cHMuY29tPC9hPjxicj4KIFNlbnQ6IEZyaWRh eSwgT2N0b2JlciAxMSwgMjAxMyA3OjIzOjMzIEFNPGJyPgogU3ViamVjdDogW0FWUi1DaGF0XSBp bnRlcnVwdCBwcmlvcml0eTxicj4KIDxicj4KIDxicj4KICZuYnNwOzxicj4KIDxicj4KIDxicj4K IDxicj4KIEhpIGRlYXI8YnI+CiBpZiBteSBwcm9ncmFtIGlzIGV4ZWN1dGVkIFRJTUVSMCBzZXJ2 aWNlIHJvdXRpbmUgYW5kIFRJTUVSMTxicj4KIE9WRiBpbnRlcnVwdCBvY2N1cnMgd2hhdCBpcyBo YXBwZW5pbmc/PGJyPgogdGhhbmtzIGZvciB5b3VyIHJlcGx5IDwvc3Bhbj48L2Jsb2NrcXVvdGU+ PC9kaXY+PC9kaXY+
2013-10-12 by David Kelly
I think it is bad practice to spend a lot of time during an interrupt service. Perhaps time to rethink your coding philosophy? Have seen a lot of people do *all* their calculations in interrupt, which is a crude way to make a "real time system" but if you have more than one interrupt source its a mess.
You might manually re-enable interrupts in your TIM0 service routine. This will let timer1 OVF run immediately. But its opening a can of worms. If TIM0 depends on anything the overflow routine is doing, and vice versa, you have a mess.
David Kelly N4HHE, dkelly@HiWAAY.net
Whom computers would destroy, they must first drive mad.
2013-10-12 by David VanHorn
I agree, interrupts should be as short as possible. Set flags, put stuff in or out of buffers, and get out. Let the non int code handle the rest. I have never had to stack interrupts for any reason.
