AVR-Chat
Re: [normal] [AVR-Chat] fuse bit problems!
2004-07-19 by H. Carl Ott
In ponyprog  (checked = programmed = 0) Erased fuses read 1 like any other
eeprom location.
  I believe you'll need an external clock oscillator fed in the mcu, just
an xtal won't do it.
  After you re-program the fuses, you can set any option you want.
-carl
At 04:39 AM 7/19/2004, you wrote:
>HI!
>(mega8535 or mega16 )
>I used  external clock  and read fuse bits all clear.(IN PONY means
>all ones)!!!(in contrast to data sheet).
>Then for crytal (7.3728MHZ)I did like this :
>11110(ckel3...1=1,ckopt=1).
>but it didn't answer me at all(devic missing)!!!
>What should I do to use a crystal(7.3728MHZ).
>Please guide me!
>Thank you.
