AVR-Chat
alarm switch
alarm switch
2004-11-09 by Dave Mucha
Hi all,
I am looking an alarm type switch and am thinking of using a Tiny11
to generate a pulse of something like 10khz and then send that thru
the 6 to 10 switches (in series) and then use the same Tiny11 to
detect that pulse.  Any switch opens and the pulse is lost.
An alternate is to use a pair, one to generate and one to detect.
BTY, does anyone know if there will be another group buy ?
Dave
Re: [AVR-Chat] alarm switch
2004-11-09 by Leon Heller
To: AVR-Chat@yahoogroups.com
Sent: Tuesday, November 09, 2004 2:42 PM
Subject: [AVR-Chat] alarm switch
Hi all,
I doubt if Chetan will be organising another, as he's got all he needs. Why
not organise one yourself?
Leon
Re: alarm switch - group buy
needs. Why
> Leon
If I remmeber correctly, someone went to a seminar and after the
seminar, attendees were offered an 'all you can buy' price of 25
cents each.
I'm not sure if that offered one specific chip and package  or some
variations ?
I know of some people that buy PIC's in the thousands, but then you
are locked into their specific chip and package.  Always seems to be
an odd chip.
I wonder if there is interest in a group buy ?
Dave
Re: alarm switch
Correct, it is a series loop.
It is for a machine where the wires can be cut or vibrate open or be
shorted.
The current or pulse would offer a more accurate way to verify that
the switches are in the circuit.
Dave
--- In AVR-Chat@yahoogroups.com, Dave VanHorn <dvanhorn@d...> wrote:
> At 09:42 AM 11/9/2004, Dave Mucha wrote:
> >Hi all,
> This is just a series loop, right?
> No need for pulses, just give a current of 10-20mA and detect
open/closed
> with debounce of about 100mS. Protection of your inputs and outputs
is more
> interesting.
> For a moment, I thought you meant addressable switches, as
in "which switch
> is open".
> Years and years ago, I did something like this in discrete logic
(yecch!)
> It sent a wide sync pulse, then narrow polling pulses down a single
conductor.
> Another conductor carried back answering pulses from each switch.
> Today, a single Tiny-11 at each switch point could work, but you'd
have to
> program in their address ranges. A micro with more pins would allow
a
> dipswitch to set that. Four pins for a 0-F dipswitch, and four
switch
> inputs, plus two pins for data, would be nice.
2004-11-09 by Dave VanHorn
>Hi all,
No need for pulses, just give a current of 10-20mA and detect open/closed
with debounce of about 100mS. Protection of your inputs and outputs is more
interesting.
For a moment, I thought you meant addressable switches, as in "which switch
is open".
Years and years ago, I did something like this in discrete logic (yecch!)
It sent a wide sync pulse, then narrow polling pulses down a single conductor.
Today, a single Tiny-11 at each switch point could work, but you'd have to
program in their address ranges. A micro with more pins would allow a
dipswitch to set that. Four pins for a 0-F dipswitch, and four switch
Re: alarm switch
2004-11-09 by slaw999
Dave,
Sounds like a failsafe design is required. Most failsafe
implementations require switches that have both a Normally Open and
Normally Closed contacts. This would require 2 conductors, wired in
series, to each switch. Depending on the type of switch, the contacts
are either "make before break" or "break before make". In either case
the intermediate "break" state is usually not more than a few ms. You
would then monitor both the Normally Open and Normally Closed
circuits, requiring 2 inputs. If both circuits remain Open or Closed
then we have an indeterminate state that should be handled as if the
machine cover is open and an indication that maintenance to repair
the problem is required.
be
> shorted.
> Dave
> > >Hi all,
Tiny11
thru
> open/closed
outputs
> is more
> > interesting.
> in "which switch
> > is open".
> (yecch!)
single
> conductor.
you'd
> have to
allow
> a
> switch
2004-11-09 by Jim Wagner
Dave -
I don't see your reason for using pulses. Why not just a
soft pull up at one end (say, the receiving end), a hard
pull down at the other. Then, if any switch opens, the
pull-up end goes high and you have it.
Jim
On Tue, 09 Nov 2004 14:42:23 -0000
 "Dave Mucha" <dave_mucha@yahoo.com> wrote:
> Hi all,
> using a Tiny11
> that thru
> Tiny11 to
> detect that pulse.&nbsp; Any switch opens and the pulse
> is lost.
> detect.
> Dave
> Yahoo! Groups Sponsor
>   ADVERTISEMENT
> To visit your group on the web, go
> to:http://groups.yahoo.com/group/AVR-Chat/&nbsp;
> To unsubscribe from this group, send an email
> to:AVR-Chat-unsubscribe@yahoogroups.com&nbsp;
> Your use of Yahoo! Groups is subject to the Yahoo! Terms
> of Service.
The Think Different Store
http://www.thinkdifferentstore.com/
For All Your Mac Gear
Re: [AVR-Chat] Re: alarm switch
A pulse won't help you. Vibrated open or short situations
will still be an open or short circuit. I suggest that you
use a steady-state voltage as I suggested in my earlier
post, then digitally filter. That will do a LOT more for
you than pulsing.
Jim
On Tue, 09 Nov 2004 15:21:18 -0000
> open or be
> shorted.
> verify that
> Dave
> > >Hi all,
> then send that thru
> the same Tiny11 to
> the pulse is lost.
> and detect
> open/closed
> inputs and outputs
> is more
> > interesting.
> switches, as
> in "which switch
> > is open".
> discrete logic
> (yecch!)
> conductor.
> each switch.
> work, but you'd
> have to
> pins would allow
> a
> dipswitch, and four
> switch
>   ADVERTISEMENT
> of Service.
In the alarm industry, this is called a supervised circuit.
A resistor at the far end sets the loop current.  At the panel, a window
comparator checks that against high and low limits.  shorted loop alarms
high, open loop alarms low, short to ground or panel power also
alarms.  Design for ANY conductor to withstand short to panel power if it's
in the same cable.
