AVR-Chat
Ethernet ...
Ethernet ...
2004-11-30 by otojam11
Hi There ...
I'm working on a project where I have to check the temperature of a
room, but I must be able to check it using the Ethernet protocol, I
was wondering if I can use any AVR uCC to do so, any kind of help
would be good ...
Thanks ...
Re: Ethernet ...
2004-11-30 by Don Kinzer
> would be good ...
EtherNut is a full, open source TCP/IP stack.
http://www.ethernut.de/en/index.html
Another option is lwIP:
http://savannah.nongnu.org/projects/lwip
and uIP:
http://www.sics.se/~adam/uip/
If your device requires/supports UDP packets, you may only need a
subset (ARP, ICMP and UDP) that you could fairly easily implement
resulting in a smaller footprint.  You could even implement DHCP
(client side) if it was necessary but if you can live with a fixed IP
address you won't even need that.
If your device requires TCP, you're probably better off using
something like EtherNut that's already working and tested.
As far as the Ethernet hardware, you could look at the PacketWhacker
or NICki for prototyping:
http://www.edtp.com (scroll down the page)
Re: [AVR-Chat] Re: Ethernet ...
2004-12-02 by dkswitzer-yahoo4096@mailblocks.com
Hi all,
I've been working with the ATmega AVRs for a couple of years now and am
currently investigating using one in a TCP/IP application. With this in
mind, I obtained an AVR Embedded Web Server (AT90EIT1) from Atmel,
replaced the ATmega103 with an ATmega128, downloaded the Atmel code
modified for the ICCAVR compiler from AVR Freaks, compiled and linked
it with ICCAVR and successfully downloded, ran and made small changes
to it using a JTAGICE Mk II. (Whew!)
However, in the process, while I have come across old comments about
the EWS on the various lists, I have seen nothing recently. I further
notice that the EWS was not suggested by DOn as a starting point for
otojam11. Do I correctly infer from these observations that the EWS was
found wanting and is no longer considered a useful starting point for a
new AVR TCP/IP project?
Comments about other's experiences with the EWS are hereby solicited!
David Switzer
To: AVR-Chat@yahoogroups.com
Sent: Wed, 01 Dec 2004 00:34:51 -0000
Subject: [AVR-Chat] Re: Ethernet ...
> would be good ...
and uIP:
Yahoo! Groups Links
2004-12-02 by Tony Vandiver
David,
    I had an atmel apps engineer tell me to look elsewhere for a solution.
He recommended www.ethernut.de and www.edtp.com both of which seem to be
pretty good starting platforms.  I've used the packet whacker from edtp with
a Mega128 & it worked although I've got a few bugs to work out.  I think it
was a good starting platform along with the book.  I laid out a board to
accept the packet whacker (if you go this route, make sure you get the
correct whacker version pinouts first) and within a day I was pinging and
UDPing with no rtos and no tcp/ip stack.  Total pkg cost for book and packet
whacker module was around 100USD.  They are to be coming out with a demo
board with a CF 802.11b card and Mega128 very soon.
hth,
Tony Vandiver
btw, thanks to the aforementioned Brian H. for the help.
To: <AVR-Chat@yahoogroups.com>
Sent: Wednesday, December 01, 2004 7:51 PM
Subject: Re: [AVR-Chat] Re: Ethernet ...
> Hi all,
> Regards,
> David Switzer
> From: Don Kinzer <dkinzer@easystreet.com>
> > would be good ...
> and uIP:
