AVR-Chat
Re: [AVR-Chat] Are 1% resistors good enough for ADC voltage dividers?
2005-01-21 by Jim Wagner
It depends on the accuracy YOU need. There are several
factors that contribute:
1. The referemce
2. The ADC conversion accuracy
3. The external circuit accuracy
If you use all 10 bits, then you can resolve 1 part in
1000, basically.
But, if you use the internal reference, you are within a
few percent, at best. If you use Vcc, you are within the
accuracy spec of your supply (5% or worse, usually). You
can get external references that will do a lot better than
1% (but you have to pay for that precision).
If your reference isn't better than 1%, you won't get 1%
with 1% resistors.
Jim
The Think Different Store
http://www.thinkdifferentstore.com/
For All Your Mac Gear
2005-01-21 by Dave VanHorn
At 07:43 PM 1/20/2005, James Washer wrote:
>I'm just starting to play with the ADC capabilities of the AVR... Are 1%
>resistors what everyone uses, or do I need something more precise?
It all depends..
There's all kinds of fun to be had in precision land, but remember, every
resistor is exactly what it is.. It may be marked 10,000 ohms, and actually
be 10,050 ohms, but a meter can sort that out for you.
I use 1% resistors in some designs, and 5% in others, it depends on the
relative cost and availability, against what I'm trying to accomplish.
Re: Are 1% resistors good enough for ADC voltage dividers?
2005-01-21 by Graham Davies
> the ADC ... Are 1% resistors
> what everyone uses ...
Are you sure this is what you want to know? In my case, yes, I use 1%
resistors in analog circuits around the ADC. But your needs may be
different from mine.
> ... or do I need something more
> precise?
You say "play", so I think the answer is no, use 1%. To properly
answer the question, we would need to know what you are trying to do
and what your circuit is (i.e. how many resistor tolerances are
adding up in your error).
It has been suggested that you can use a meter to measure the
resistance accurately. Many meters have accuracies of less than 1%
and if you are "playing" this is probably what you have. Take a look
at your meter specs before you trust its reading more than the
nominal value of a 1% resitor.
Graham.
