AVR-Chat
need help programming / project
2005-02-18 by Dave Mucha
Hi all,
I am in need of a circuit that can detect mating to another part.
Think door lock and keys, or party  favors... ??
It would be that one part would be connected to another of about 40
possible combinatoins, and only if it is correct would the thing
work.  say, light an LED or something.
I'm thinking when the two parts meet, they both light an LED to
indicate the correct two were connected.
I am looking for someone who can lay out the curcuit, schematic,
program the micro test it.
The probably power will a cell phone (or similar) battery.
And, no, I do not expect it will be free.
I can make my own PCB's, but if you need to that is fine.
any takers ?
I have some additional details, but that is the basic project.
if, you can't get my e-mail from yahoo, try
dave_mucha  at  yahoo  dot com
Dave
Re: [AVR-Chat] need help programming / project
2005-02-18 by Stefan Trethan
On Fri, 18 Feb 2005 16:49:29 -0000, Dave Mucha <dave_mucha@yahoo.com>
In exactly which form do they "mate"? ;-)
Do they have contacts or connectors of some sort?
Have you cosidered using DBx connectors and simply wiring different pins?
ST
Re: need help programming / project
--- In AVR-Chat@yahoogroups.com, "Stefan Trethan"
<stefan_trethan@g...> wrote:
> On Fri, 18 Feb 2005 16:49:29 -0000, Dave Mucha <dave_mucha@y...>
40
pins?
> ST
The mating would be by being next to each other.  maybe a contact
type connection, but not plugs or any type of protruding contacts.
Think of a deck of cards that would be flat and need to touch to be
identified.  (really close is fine)   alignement is fine if an opto
sensor were to be used.  ie: serial handshaking.    RF is not desired.
Dave
Re: [AVR-Chat] Re: need help programming / project
On Fri, 18 Feb 2005 18:14:31 -0000, Dave Mucha <dave_mucha@yahoo.com>
> Dave
I suggest either using IR or using inductive transmission (coils).
Do the devices have batteries?
Are there "male" and "female" devices, or can they mate freely?
(in other words are some TX and some RX or are they all TX/RX)
ST
> On Fri, 18 Feb 2005 18:14:31 -0000, Dave Mucha <dave_mucha@y...>
be
opto
desired.
> > Dave
> ST
IR would be fine, prefer to have extreemly close and not something
that would work more than an inch apart.
And, yes, each unit will have a battery.  Most likely a flat cell
phone batt or similar
Dave
> On Fri, 18 Feb 2005 19:26:17 -0000, Dave Mucha <dave_mucha@y...>
> > Dave
> I think coils would be better then.
> My guts tell me it is easier to make it only work on close
distances with
> coils. Light doesn't work well that way i fear, in air.
> Can you guarantee some sort of alignment, like, imagining the pack
of
> cards, that it would always lie flat and never stand on-edge? The
RFID
> systems seems to have big problems with alignment, so if you were
to use
> field strength as distance indicator you'd need to guarantee some
> alignment. I think the coupling between two flat coils could be
used well,
> know the inductive-recharge contactless toothbrushes?
> Sound might be another option, but can be disturbed by noise,
depends on
> what you are doing.
> Electric contacts seem only reasonable if you can ensure
positioning etc.
> ST
yes,  postioning and alignment can be guaranteed.  One option is to
align them with dimples and to connect them with magnets.
Dave
On Fri, 18 Feb 2005 19:26:17 -0000, Dave Mucha <dave_mucha@yahoo.com>
> Dave
My guts tell me it is easier to make it only work on close distances with
Can you guarantee some sort of alignment, like, imagining the pack of
cards, that it would always lie flat and never stand on-edge? The RFID
systems seems to have big problems with alignment, so if you were to use
alignment. I think the coupling between two flat coils could be used well,
Sound might be another option, but can be disturbed by noise, depends on
what you are doing.
Electric contacts seem only reasonable if you can ensure positioning etc.
ST
On Fri, 18 Feb 2005 20:28:29 -0000, Dave Mucha <dave_mucha@yahoo.com>
> Dave
:-))) i can imagine something really nice with small neo magnets.
place 2 in each device, one north down and one south down, and let the
alignment magic commence ;-)
Ok, this way optical would be easily possible, and even electric contacts,
but i dunno if contacts are the better idea (dirt and stuff). Put in some
tiny atmel and let it send a serial code which the other device
recognizes, and you are done.
Now why do you want someone to do that for you? you can easily do it
yourself.
ST
2005-02-18 by Dave VanHorn
Well, that's the sort of thing I do..
I've watched the emails, but I'm just getting back up to speed.
Sounds like you're not married to a particular technology, but the
requirements are pretty vague.
Should we talk privately under an NDA?
2005-02-19 by Joe
How about magnets on one side and reed switches or halleffect sensors
on the other side?
JoeT
about
> 40
different
> pins?
> > ST
desired.
> Dave
