AVR-Chat
was eeprom ? Now about disasm
2005-04-26 by arhodes19044
I can not find the source files for the eeprom routines in libc.  I
want to disable interrupts for the minimum necessary period while
writing to EEPROM.  I bet that the clear/set should occur in the
write_byte function, since that is probably called by all the larger
size write functions.
How do I disasm only the required parts.  How do I even SEE the
disasm'ed code while running avrsrudio?  I have "accidentally" landed
in the disasm'd code, I think, while in avr-studio, but I have never
intentionally found it.
If necessary, I could write my own multi-byte function that clears
interrupts just before invoking the write_byte function, then resets
them upon return.  It would not be hard to do, But I'd rather take the
functioning code and insert a cli and sei in between a couple of lines.
-Tony
Re: [AVR-Chat] was eeprom ? Now about disasm
2005-04-27 by David Kelly
The sources are:
/* write a byte to EEPROM */
/* void eeprom_write_byte(uint8_t *addr, uint8_t val); */
/* addr = r25:r24, val = r22 */
#define val rP3
         .global _U(eeprom_write_byte)
_U(eeprom_write_byte):
         sbic    _SFR_IO_ADDR(EECR), EEWE
         rjmp    _U(eeprom_write_byte)   /* make sure EEPROM is ready */
#ifdef EEARH
         out     _SFR_IO_ADDR(EEARH), addr_hi
#endif
         out     _SFR_IO_ADDR(EEARL), addr_lo
         out     _SFR_IO_ADDR(EEDR), val
         in      __tmp_reg__, _SFR_IO_ADDR(SREG)
         cli                     ; /* no ints between setting EEMWE and
EEWE */
         sbi     _SFR_IO_ADDR(EECR), EEMWE
         sbi     _SFR_IO_ADDR(EECR), EEWE
         out     _SFR_IO_ADDR(SREG), __tmp_reg__
         ret
#undef val
/* write a block of bytes to EEPROM */
/* void eeprom_write_block (const void *buf, void *addr, size_t n); */
/* buf = r25:r24, addr = r23:r22, n = r21:r20 */
         .global _U(eeprom_write_block)
_U(eeprom_write_block):
         cp      n_lo, __zero_reg__              ; check if really there
is something to write
         cpc     n_hi, __zero_reg__
         breq    eeprom_write_block_done
         LOAD_X(buf_lo, buf_hi)
         in      buf_lo, _SFR_IO_ADDR(SREG)      ; reuse buf_lo as the
SREG temporary storage
eeprom_write_block_busy:
         rjmp    eeprom_write_block_busy         ; make sure EEPROM is
ready
#ifdef EEARH
#endif
         ld      __tmp_reg__, X+
         out     _SFR_IO_ADDR(EEDR), __tmp_reg__
         cli                                     ; no ints between
setting EEMWE and EEWE
         out     _SFR_IO_ADDR(SREG), buf_lo
         subi    addr_lo, lo8(-1)
         sbci    addr_hi, hi8(-1)
         subi    n_lo, lo8(1)
         sbci    n_hi, hi8(1)
         brne    eeprom_write_block_busy
eeprom_write_block_done:
         ret
If you still have the Makefile I sent a while back, posted to the list,
it creates "object.elf" which is loaded into AVRStudio for debugging,
but also generates a text file named "object.list". I add object.list
to my PN2 project for quick access. Then text search (control-F) for
the string of interest.
> How do I even SEE the disasm'ed code while running avrsrudio?
Right mouse click on the source window, "view disassembly" or something
obvious to that effect. I have problems with AVRStudio getting out of
sync with the C source lines, stopping in mid-statement, and
automagically opening a disassembly window.
One advantage of using object.list described above is that the line of
C source code is inserted as comments immediately prior to the
generated code. AVRStudio does not insert the C source, but does
provide verbose descriptions of each assembly instruction.
Believe the command line to generate object.list is:
avr-objdump -DS object.elf > object.list
David Kelly N4HHE, dkelly@HiWAAY.net
Whom computers would destroy, they must first drive mad.
Re: was eeprom ? Now about disasm
2005-04-27 by arhodes19044
AHA!  That sourfce does it.  I see that the interrupts are ALREADY
cleared in the source you gave me.  I also get the disasm version of
my code and I see that the libc looks to be identical.
In the Disasm, I can see that the interrupts are cleared.  I could
not see where they were set again, but in the original source you
include, I see that a register is used to store SREG, and then to
restore it.
So, it seeme to me that the interrupts ARE suspended in the libc
versions.  I was under the impression that they did not suspend
interrupts, but I can see the cli.
So, I do not need to hand-tune the library eeprom handlers to
suspend interrupts.  I forget what made me think that the library
routines did not clear interrupts....
THANKS!  You helped me a lot, and also saved me some time trying to
write my own stuff.
-Tony
libc.  I
larger
> The sources are:
> #define val rP3
ready */
> #ifdef EEARH
> #endif
EEMWE and
> EEWE */
>          ret
> #undef val
n); */
there
EEPROM is
> ready
> #ifdef EEARH
> #endif
>          ld      __tmp_reg__, X+
>          subi    n_lo, lo8(1)
>          sbci    n_hi, hi8(1)
>          ret
list,
debugging,
object.list
for
something
of
line of
> David Kelly N4HHE, dkelly@H...
Re: [AVR-Chat] Re: was eeprom ? Now about disasm
> restore it.
Thats how its done. In a generic library such as avr-libc one does not
want the global interrupt flag to be different on exit than on entry. So
SREG is stashed, cli, bits twiddled, and SREG restored to return to
whatever was originally in effect.
> write my own stuff.
Its more fun to write your own.  :-)
Spent some time playing and my C routines are only a couple of bytes
larger than the handcrafted assembly. I'll keep my C versions in my
project, partly because everything one uses in a library becomes a risk
5, 10, or 20 years down the road. Partly because I want a wdt_reset().
Partly because I also want an ee_compare() to verify the contents of
SRAM and EEPROM match:
//	Compare EEPROM contents against SRAM
//		addr is the address within the EEPROM
//		cp is what to compare in RAM
//		n is the number of 8 bit octets to compare
//	Returns 0 if contents match, following memcmp() precedent.
//	(this code is almost exactly ee_reads().
int
ee_compare(void *addr, const void *cp, uint16_t n)
	int tmp;
	for( ; n ; n-- ) {
		wdt_reset();
		while( EECR & (1<<EEWE) )	//  wait until ready
		EEAR = (uint16_t)addr;
		EECR |= (1<<EERE);	//  start the read
		tmp = *((uint8_t*)(cp)++) - EEDR; //  read
		if( tmp )
			return(tmp);	//  fail, difference between
		addr++;
	return(0);	//  pass
