AVR-Chat
Watchdog bites
Watchdog bites
2005-07-28 by Bruce Parham
All,
Thanks for all the comments on bogus op-codes. The boot loader code is about done.
I'm at the point of exiting the loader and starting the application code but haven't
decided which way to go. The original application code was done assuming that the cpu
would startup from a reset though it may work just fine using a jump to 0x0000.
I started playing with the watchdog timer in Studio sim and it does work but the timing
is way off vs the data sheet specs. Enabling the timer with the prescaler bits all clear
should result in a 14-15 ms timeout but Studio sim pops to the reset point in something
under 2 ms. This all may just be a sim bug, like SPM page erase and writes only taking
one clock cycle, no big deal. The other issue, and on this the data sheet says nothing,
is that the WD timer is still enabled after the timer triggered reset.
Does anybody have any insights as to how the real hardware does it? Is it still enabled
after a reset? If it is, I'll need to set the timer for a longer period to get through
the app startup.
Thanks in advance.
Bruce
Re: Watchdog bites
2005-07-29 by arhodes19044
Unfortunately, I have no specific experience with the watchdog
timer.  But, I have had siginficant trouble with the simulation of
timers in general, triggering of timer interrupts in the simulator.
I have tried the simulator for my 128.  Out of frustration I
eventually set the simulator to mimic the 103 and it worked with
fewer bugs.
Atmel confirmed the bugs (rather than my own errors) but effectively
said that they had no timetable for fixes.
So, one thing you could do is to try setting the simulator to
emulate some earlier uC that has the same hardware that you are
using (if it is missing stuff you do not use, then it may not be a
problem).
This way you might be able to tell if it is a bug in the simulator
or your own code.
I have essentially given up simulating my code for the 128.  It is
much too dependent on timers and outside input to do anything
meaningful in the simulator. Nevertheless, I would have had my life
made so much easier in the beginning if the simulator worked
properly.
I would much rather not have certain functions simulated at all,
rather than have them simulated incorrectly.  Random undocumented
bugs and errors make the simulator nearly useless IMHO.
I thin that certain earlier processors have had all the simulator
bugs eliminated.  BUt not the 128.
-Tony
--- In AVR-Chat@yahoogroups.com, Bruce Parham <obparham@j...> wrote:
> All,
code is about done.
jump to 0x0000.
reset.
> the app startup.
> Thanks in advance.
> Bruce
Re: Watchdog bites
2005-07-30 by Don Kinzer
> does work but the timing is way off vs the data sheet specs.
I wouldn't trust the simulator much for anything other than
arithmetic/logic.  In my opinion, a simulator is not of much value
when you can try things out on the "real thing" and not have to worry
about simulation-induced errors and anomalies.  Get yourself a JTAG
ICE device and have at it.
I have used the original JTAG ICE which I got free for attending an
Atmel seminar.  Depending on which chip you want to use you may need
to get a JTAG Mk II.  Although I haven't used it myself, I've heard
good things about the ECROS Technology JTAG device which costs less
than the one from Atmel.
http://www.ecrostech.com./Products/AvrJtagIce/Intro.htm
> Is it still enabled after a reset?
No, the watchdog timer is not enabled after reset.  If you look at the
datasheet for the device you'll see that the all the bits of the WDTCR
register have an initial value of zero.  The initial values prevail
after any of the reset events (power on, external reset, etc.).
Don
