AVR-Chat
Re: [AVR-Chat] Two or more serial ports
2005-08-01 by Leon Heller
To: <AVR-Chat@yahoogroups.com>
Sent: Monday, August 01, 2005 4:41 PM
Subject: RE: [AVR-Chat] Two or more serial ports
Try the MAX3110E spi uart.  Makes it simple to add as many real hardware
uarts as you need to any project.
Or, check out http://www.atmel.com/dyn/resources/prod_documents/doc2557.pdf
and just add as many mega8's as you need serial ports to your project.  It
is probably cheaper than the MAX part...
Having used the maxim chip, I'd go for option B.
There are some tricks to the max chip that are a bit non-obvious that you
don't have to put up with using AVRs, and you can also probably export some
of the application's "smarts" to them, and offload from the main processor.
I've used multiple '2313s as serial ports, connected via software SPI..
Leon
Checked by AVG Anti-Virus.
Version: 7.0.338 / Virus Database: 267.9.7/60 - Release Date: 28/07/2005
[This E-mail has been scanned for viruses but it is your responsibility
to maintain up to date anti virus software on the device that you are
currently using to read this email. ]
