T26 ADC reading 2X reality?
2005-08-16 by Dave VanHorn
(apparently this didn't make it, the first two times I sent it, so I'm plugging it in again from the web interface.) I'm not sure if this is an on-chip problem, or off chip.. I have a T26, measuring current by a differential measurement, using the G=20 amplifier. Explaining the whole thing in detail would be tedious, but I'm doing high side current measurement with resistors scaling down the inputs so that I don't rail out the ADC. I am using an external 2.5V reference, and I've verified that it's in tolerance. (2.458V) In the existing setup, I am seeing about 180 counts on the ADC, but running the math on the external parts says that I should be seeing closer to 90 counts. IOW, the system thinks the current is about twice what it really is. This is a mature system, not a prototype, and has been in production for some time.. Date codes on the chips don't seem to matter (I've tried various ones all the way back to "ES"), and the existing firmware works fine in older "known good" boards. This does seem to be a problem on some number of boards. Others seem ok, but I am waiting on confirmation of that. The ADC is not overclocked. What could cause the ADC readings to be almost (but not exactly) twice what they should be, assuming that it's not a firmware change, and that the components pass visual inspection, plus the voltage measurements confirm the component values and PCB connectivity?
