AVR-Chat
Where to start with AVR
2006-01-10 by Mark Weston
Another excellent way to start is with an ATMega32 kit
from Eddy Wright @ WWW.WrightHobbies.NET.  for $35.00
US you get a kit to build a controller with AtMega32,
programming pins brought out to the standard 10pin ISP
header, ISP dongle for programming, and a software CD
that includes the freeware version of BascomAVR Basic.
It only takes a half hour to assemble and you're good
to go.
Mark Weston
__________________________________________________________
Find your next car at http://autos.yahoo.ca
Re: Where to start with AVR
2006-01-11 by Stefan Wimmer
--- In AVR-Chat@yahoogroups.com, Mark Weston <weston54@y...> wrote:
> ... AtMega32, programming pins brought out to the standard 10pin ISP
header
BTW - there seems to be a new standard:
The new AVRISP mkII only has the 6-pin connector.
2006-01-11 by Don Kinzer
It's not particularly new.  The STK500 has both 6-pin and 10-pin ISP
connectors.  The ATAVRISP also has both.
Don
ZBasic Microcontrollers
http://www.zbasic.net
ISP Standard..Re: [AVR-Chat] Re: Where to start with AVR
2006-01-12 by James Washer
What I cannot figure out is why they didn't bring SS out to the 10-pin header (replacing one of the ground leads) thereby allowing developers to use the same header for both ISP and SPI
On Thu, 12 Jan 2006 00:12:42 -0000
> Don
2006-01-12 by Don Kinzer
Since pin 3 of the 10-pin configuration is not used, you could patch-
wire SS to that pin.
Don
Re: ISP Standard..Re: [AVR-Chat] Re: Where to start with AVR
Of course... thanks
On Thu, 12 Jan 2006 03:08:07 -0000
> Don
2006-01-12 by Klaus Ruebsam
AFAIK the 6 pin version is the original Atmel idea behind, the 10 pin
version originated from Kanda
Klaus
Lust, ein paar Euro nebenbei zu verdienen? Ohne Kosten, ohne Risiko!
Satte Provisionen f�r GMX Partner: http://www.gmx.net/de/go/partner
2006-01-12 by Stefan Wimmer
Yes, of course the 6-pin header isn't new per se, but since the new
AVRISP mkII has only this type, it will be the new standard after years
of using the 10-pin variant for many of us.
I'm using AVRs almost from the very beginning of their appearance and
the first available development system (STK200) had the 10-pin ISP
connector...
2006-01-12 by Dave VanHorn
> connector...
Same here, but I've been using the 6 pin for years. Never understood
why you'd want the 10 pin anyway.
2006-01-13 by James Washer
It's much easier to find 10p IDC connectors
ISP-connectors and their origin (was: Where to start with AVR)
2006-01-13 by Klaus Ruebsam
As the AVRISP mkII has been developed by Atmel.
>... and the first available development system (STK200) had the 10-pin ISP
> connector...
and was developed by Kanda (which is the reason for the 10 pins)
Klaus
10 GB Mailbox, 100 FreeSMS/Monat http://www.gmx.net/de/go/topmail
+++ GMX - die erste Adresse f�r Mail, Message, More +++
