AVR-Chat
(Not in Scope)
(Not in Scope)
2006-02-15 by houman
hi everyone,
I had a problem about debugging programs in avr studio.I load the obj
file created with codevision and run the simulator.I can see the
general purpose registers and other registers' value, but the thing is
when I drag a variable to watch window it says not in scope.
even when I drag TCNT0 it gives me the same massage.Would you please
help me on this matter.
thanks,
Houman
Re: [AVR-Chat] (Not in Scope)
2006-02-15 by Ned Konz
> thanks,
I don't know about Codevision, but in avr-gcc, registers like TCNT0
aren't really variables; they're actually #defined as lvalue
expressions like this:
#define TCNT0 _SFR_IO8(0x32)
which then expands to
(*(volatile uint8_t *)((0x32)+0x20))
and so they're not really variables (and can't be watched, unless you
have the ability to watch an arbitrary expression like that).
Instead, you can look at the RAM space at the right address (in this
case, on the Atmega128, it would be RAM address 0x52). (Or register
0x32, when used with the IN or OUT instructions).
Re: (Not in Scope)
2006-02-18 by houman
the obj
thing is
please
> > thanks,
TCNT0
you
this
register
thanks for your message.I could solve the problem.I should have
Loaded the file with .coff extension in order to be able to watch
the varibles.
