One of >46 pin project
2006-05-25 by Nathan Nottingham
For my next project, I'm fairly convinced that there are no reasonable PIC solutions that fulfill my requirements so I'm ready to switch over to the AVRs. I need at a minimum 46 I/Os, which Microchip accommodates fairly easily but Atmel doesn't seem to have anything between 35 and 53 pins. Since this is a 'one of' project, the ability to etch and solder by hand is something of concern. I've trolled a bunch of data sheets but can't find a relatively easy to solder package with >46 pins from Atmel. Did I miss something or do I just need to bite the bullet? Second question: My experience with LCDs is limited to working with serial->parallel shift registers in order to interface with the LCD. What is the general feeling about using a 'LCD' AVR as a possibly more convenient method of communication with the display? Third question: I have a ICD2 debugger which I use constantly when developing PIC based projects (stems from my inability to read my own code :) What is the AVR equivalent in terms of ability and cost? Am I correct in assuming that a decent AVR debugger will also do in circuit programming (The programmer I own is only capable of writing to very mature AVR products) Looking forward to turning to the dark side of the Force, Nate
