To: AVR-Chat@yahoogroups.com
Sent: Sunday, September 10, 2006 12:40 PM
Subject: [AVR-Chat] Re: GP2D02 + ATmega32
Ok, since the reply to this post showed that obviously some
knowledge was lacking in this area I have gone away and redone my
coding and interfacing to the GP2D02.
I've gotten the input correct now (I mistook the pulsing of the
input line to be a PWM.. silly me..) and have witnessed the IR flash
(via camera).
It is the output from the sensor which is of concern now... for some
reason the output is forever high.. for example, when i want to take
a reading i make my input line low, to which the sensor responds by
making the output low during the reading, and then high, to which my
code response by starting the pulses to read each bit in.
Yet for some reason the output bit is always high... my 'output'
variable is always "255" DEC regardless of the distance the sensor
is to a surface..
am I still missing the mark here? =(
--- In AVR-Chat@yahoogroups.com, "Larry Barello" <yahoo@...> wrote:
> Don't use PWM output to drive the unit. Have you seen
> http://www.barello.net/Papers/GP2D02?
> The assembly code is complex since it multiplexes three sensors
but at it's
> core it is simple, it does the clocking and shifting of data in
s/w which is
> more than fast enough and easy to control. I paraphrase below,
for one
> sensor (I used 9 for the loop to discard the first bit, you could
re-arrange
> and make it 8 loops):
> Set control port pin low
> wait for input pin to go high (or a max of 30ms IIRC)
> for (i = 0; i< 9; i++)
> if input high
> output |= 1; // Set low bit
> output << 1; // Left shift
> set control pin low // Clock in next bit
> wait 1 us
> set control pin high
> wait 16 us
> set control pin high.
> At the end of the routine your data should be in "output" and the
sensor
> should be in a low-power state ready for another reading. Please
make sure
> the code you write follows the clock diagram in the data sheet. I
just
> paraphrased assembly code I wrote over 7 years ago and might have
made a
> mistake or two...
> Larry Barello
> www.barello.net
> | -----Original Message-----
> | From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com]
On Behalf
> | Of katraven1
> | Sent: Thursday, August 31, 2006 8:54 AM
> | Subject: [QUARANTINE] [AVR-Chat] GP2D02 + ATmega32
> | Importance: Low
> | Hey guys, me again =P
> | I've been spending the last couple of days trying to get one ex-
Sharp
> | infrared sensor to communicate wif my ATmega32. It's jst
connected to
> | the OC0 pin on PORTB generating a pwm to read a signal and the
output
> | of the sensor to one of the other IO pins, similar as used on the
> | Dilberts (thx Larry!)
> | However, as the output of the sensor is in serial, I can't quite
get
> | the timing right to read it properly...
> | I've read the previous post which converts code for the BSII to C
> | (http://groups.yahoo.com/group/AVR-Chat/message/7190) but I'm not
> | quite sure how to build on top of that...
> | *boggled yet again....
