AVR-Chat
OT HC595 AND PIC GLITCHES
2006-09-07 by oldhat_owen
I know this is perhaps a bit off topic but I have several boards with
PIC16F877 processors driving an HC595 shift register and the output
pins from the pic driving the HC595 are virtually all glitches.
It is hard to pick up a high or low as such on the logic analyser
other outputs seem ok, has anyone any idea what may be causing this.
And yes I do not like pic's I normally use AVR'S.
Owen.
Re: [AVR-Chat] OT HC595 AND PIC GLITCHES
2006-09-07 by Zack Widup
I have a couple questions:
1 - What frequency is the PIC running at?
2 - Are the DC input leads to the PIC and the 74HC595 adequately bypassed
with capacitors? (I'd assume you did this properly).
3 - Are all ground leads on the PIC grounded? I just about went around the
bend once trying to figure out why one 16F877 circuit wouldn't work and
found I'd forgotten to ground one of the ground leads. It worked fine once
I did that.
4 - What is the duration of the pulses from the PIC to the HC595 that
you're sending, per your program?
Zack
> Owen.
2006-09-07 by Leon Heller
To: <AVR-Chat@yahoogroups.com>
Sent: Thursday, September 07, 2006 3:06 PM
Subject: [AVR-Chat] OT HC595 AND PIC GLITCHES
Perhaps you are having read/modify/write problems, are you using the bit
manipulation instructions?
Leon
RE: [AVR-Chat] OT HC595 AND PIC GLITCHES
2006-09-07 by OWEN-A
20MHZ
100NF FOR EACH
I did that.
ALL GROUND LEADS ARE GROUNDED
NOT 100% SURE  THERE ARE AT LEAST 10 nop's BETWEEN EACH TRANSITION
This is not my circuit or my code it is a fix up job for a system where the
original designers have quit "ex gone broke".
There are quite a few of these units in the field.
The logic analyser is capable to 50MHZ but on these lines it misses the
pulses and will only pick up a signal when glitch detection is turned on.
Thanking you,
Owen.
Zack
> Owen.
Yahoo! Groups Links
Using  bsf  and bcf   PORT?,n
Thanking You,
Owen.
Leon
Yahoo! Groups Links
2006-09-07 by Roy E. Burrage
If it's someone else's design and also their code, considering that they
have gone Tango Uniform in the mean time, you might be better off to
just take the original specs and start all over from scratch Owen.  If
there are a number of boards out in the field, so be it.  If yours is
form, fit, and function compatible there should be no problem...assuming
this is a replaceable module in another piece of equipment.  If it fits
in the same hole and connects the same way, who cares?
You can spend a lot of time to find one line of code that's out of
whack, a marginal component combination, or a marginal circuit layout.
When called in behind someone else who's gone TU, and upon explanation
that there's probably a reason for that, most customers will go with the
redesign option in my experience.
Then you can use a real controller...       :-D
REB
>20MHZ
>100NF FOR EACH
>I did that.
>Thanking you,
>Owen.
>Zack
>>Owen.
Sent: Thursday, September 07, 2006 4:09 PM
Subject: RE: [AVR-Chat] OT HC595 AND PIC GLITCHES
> Thanking You,
That could be the problem, if they follow one another (read-modify-write).
Try putting NOPs between them, or write to the whole port.
Leon
2006-09-07 by Dennis Clark
Ouch. PIC 16F parts do a read-modify-write on the IO port that a pin is
on when you use the bsf/bcf instructions, so if you do a bsf PORTA,7
you'll read all of port A, set bit 7 and then write PORTA back out.
This means that you could change any of the pins on PORTA depending upon
what was read on those lines.  A far safer way to do this is to keep a
"shadow" register for a port, do the bsf/bcf on that shadow register and
when completed write the whole register out to the port.  This will
guarantee that your bsf/bcf operations don't munge up other bits on the
port.  Thank goodness the 18F, 30/33/24F parts DON'T have this side effect.
DLC
> Thanking You,
> Owen.
> Leon
Dennis Clark    TTT Enterprises
2006-09-07 by David VanHorn
Something else to be aware of, glitches on the data pins going to the shift
registers don't matter at all, unless they are accompanied by a transition
on the clock line.
Those glitches may be intentional, driving something else.
They may be intentional, just to confuse reverse engineers.
They may be bugs.
Hard to see without a schematic.
