AVR-Chat
Timer 1 Troubles
Timer 1 Troubles
2006-12-13 by dr_bitbucket
I'm writing some assembly code for an ATtiny24 for a new project.  I
need to use timer1 to PWM output PA5 (OC1B) (pin 8, I believe) at
close to 38 kHz and 50% PW, it's for an IR LED being sensed by an
IS1U60.  I am using timer0 for PWM motor control (which works just
fine), and I would prefer to use timer1 for this application as it
offers a phase and frequency correct PWM mode, and I think that's
snazzy.
The steps I have taken to initialize my timer1:
      My DDR for port A5 has been set to output in a previous
instruction.
      I begin by writing my TOP value to 16-bit registers OCR1AH and
OCR1AL, writing high-byte before low.
      I write to TCCR1A, disabling OC1A, enabling OC1B with code
0b10, and setting Waveform Gen Mode bits 1 and 0 with code 0b01.
      I write to TCCR1B, setting Waveform Gen Mode bits 3 and 2 with
code 0b10 (which completes setting WGM to mode 9) and set my clock
prescaler bits CS1[2:0] to 0b001 for a prescale rate of CLK/1.  To
my understanding this is supposed to start the timer.
Here's the problem:
On the instruction cycle immediately following my write to TCCR1B,
Waveform Gen Mode bit 3 is cleared automatically.  This appears to
occur while flags OCF1A and OCF1B are simultaneously set, though I
am not sure if this is connected or relevant.  And the real kicker
is that the timer doesn't even appear to start:  TCNT1x registers
are not incrementing, just remaining clear.  Even if I test the
timer1 in a mode other than PFC-PWM, for example fastPWM, the timer
still refuses to start.  Has anyone seen this before (Craig???)?  It
feels like there is some kind of master control bit I have
neglected.
I am using the AVRstudio simulator config'd for an ATtiny24.  Hoping
this is a simulator bug, though it'll be a bugger to debug if it is.
Thanks for any help you can provide,
Evan Haklar
Re: [AVR-Chat] Timer 1 Troubles
2006-12-13 by Don AE5K
Evan,
I have not tried the tiny24, but on several other tiny new parts, there
is apparently a bug in the simulator with the timers and I've run into
similar strange problems.  If you dig deep enough in the online help for
the studio, there is a note in there about that as known problem.
Don
> snazzy.
> instruction.
> Here's the problem:
> neglected.
> Evan Haklar
2006-12-13 by Mark Jordan
> snazzy.
	You don't need PWM mode for 38kHz @50% duty cycle.
	Just use the Timer1 in CTC mode and adjust COM0/1.
	See the datasheet Table 14.4 mode 4.
	Mark Jordan
