AVR-Chat
*oh*
*oh*
2007-01-04 by Thomas Keller
OK.    I figured out wqhat up/downloading memory was in AVR Studio. Now,
I can see my EEPROM data when I do a memory watch.  It still isn't
coming in to my data resgister when I read it, though )-:.
Re: [AVR-Chat] *oh*
2007-01-04 by David VanHorn
Step it through, and see what it IS loading.
Check EEARL and EEARH just before the load.
Re: [AVR-Chat] *oh*
2007-01-04 by John Samperi
I have taken the liberty to rearrange your code to my
liking :) this will fetch the last data byte correctly.
Also watch out your use of r16 as it is also defined as temp.
.include "tn25def.inc"
  ; Define here the variables
  .def  temp  =r16
.cseg
  ; Define here Reset and interrupt vectors, if any
  RESET:
     rjmp 	 START
     reti      ; Addr $01
     reti      ; Addr $02
     reti      ; Addr $03
     reti      ; Addr $04
     reti      ; Addr $05
     reti      ; Addr $06        Use 'rjmp myVector'
     reti      ; Addr $07        to define a interrupt vector
     reti      ; Addr $08
     reti      ; Addr $09
     reti      ; Addr $0A
     reti      ; Addr $0B        This is just an example
     reti      ; Addr $0C        Not all MCUs have the same
     reti      ; Addr $0D        number of interrupt vectors
     reti      ; Addr $0E
     reti      ; Addr $0F
     reti      ; Addr $10
  ; Program starts here after Reset
START:
      ldi    r30,    RAMEND                    ; initialize stack pointer
      out    SPL,    r30
;    ldi    r31,    0x00	; set up EEPROM high byte address
;     out EEARH,    r31     Not used in tiny 45     ; store in register
      ldi    r31,    0x00                    ; set up upper WGM bytes
      out    WGM01,    r31                        ; and once again
      ldi    r31,    0x03                    ; set upo to set
waveform configuration
      out    WGM00,    r31                        ; output to
appropriate control register
  ;    set up timer delay for ~~.01 second
  ;    counter clock will be prescaled by 1024 to make the .01 second
count easier
      ldi    r31,    0x38                    ;  load low byte of delay count
      out    TCNT0,    r31                        ; output to counter/timer 0-
      ldi    r31,    0xe5                    ; load the control value
for  TCCR1
                                          ; CTC1 set, PWMa set, COM1A set to
                                          ; toggle on match, timer clock set
                                          ; for system clock divided by 256
      out    TCCR1,    r31                    `    ; store in register
      ldi    r31,    0x01                    ; load value for TCCR01A
      out    TCCR0A,    r31                    ; and strope to TCCR01A
      ldi    r31,    0x04                    ; load value for TTCCR01B
      out    TCCR0B,    r31                    ; output to TCCR01B
      ldi    r31,        0x00                ; load compre output macthj value
      out    OCR0A,        r31                    ; stroe in output
compare register 0A
  ;    this code sets the default initial table adress at -1.  It
will automatically
  ;    increment on the first access, to 0
      ldi    r16,table_end	;****** 0xff ;first addresss - 1 in EEPROM
table data
      ldi r17,    0x00                    ; direction control byte, 0 = up
      rcall    TABLEDATA
      rjmp    DONE                        ; all done, leave
  ;    this subroutine counts up and down through the data table in the EEPROM
  ;    data, reading all 100 data values, from bottom to top, then
top to bottom
  ;    one at a time
  NEXT:
      ldi    r30,    0x00                    ; compare value
      cp    r17,    r30                        ; check direction bit for value
      brne    UP                            ; it's set for an up count
      dec    r16                                ; count the table
pointer down one
      cp    r16,    r30                        ; at the bottom yet?
      ldi    r17,    0xff                    ; set direction flag to count up
      RJMP    QUIT0                        ; all done, depart
  UP:
      ldi    r30,    0x63                    ; compare value
      inc    r16                                ; increment table pointer
      cp    r16,     r30                        ; 99 decimal, end of table
      breq    FIXIT0                        ; deal with table overflow
      rjmp    QUIT0                        ; all done, depart
  FIXIT0:
      ldi    r17,    0x00                    ; reset direction flag
for  down count
  QUIT0:
      ret                                    ; return from subrouttine  call
  ;    read a value from the EEPROM table
  TABLEDATA:
	rcall    NEXT                        ; go grab next tabel address
     out    	EEARL,r16   ;Sets up address in EEP
     sbi   	EECR,EERE	;************* this is missing in your code
     in    	r0,EEDR   ;Get data
     ret                                 ; all done, go home
  DONE:
      rjmp DONE
  ;    this table povides the data for the intensity curve needed for
  ;    xxxxxxxxxxxxxxx.  the data represent the value sin^3 * 255 for
  ;    each angle from 0 through 90  at .9 degree increments
      .eseg
  TABLE:
      .db    0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 2, 2, 3, 3, 4, 5, 6, 6
      .db    8, 9, 10, 11, 13, 14, 16, 18, 20, 22, 24, 26, 29, 31, 34, 36
      .db    39, 44, 48, 52, 55, 59, 62, 66, 70, 74, 78, 82, 86, 90, 94, 99
      .db    103, 108, 112, 117, 121, 126, 130, 135, 140, 144, 149, 153
      .db    158, 163, 167, 172, 176, 180, 185, 189, 193, 197, 201, 205
      .db    209, 212, 216, 219, 223, 226, 229, 232, 234, 237, 239, 242
      .db    344, 346, 247, 249, 250, 252, 253, 254, 255, 255, 255
table_end:
John Samperi
Ampertronics Pty. Ltd.
11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
Tel. (02) 9674-6495       Fax (02) 9674-8745
Email: john@ampertronics.com.au
Website  http://www.ampertronics.com.au
*Electronic Design * Custom Products * Contract Assembly
Re: [AVR-Chat] *oh*
Dave, that's the point.  it doesn';t appear to be laoding ANYTHING.   I
can use thw memory watch to look at the EEPROM contents, and they are
correct (now that I know about "downloading" the eep file).  Buty
according to the debugger, NOTHING is appearing in either EEDR *OR* the
register into which I am loading the EEDR contents.  Always 0x00,
regardless of what is in the EEPROM location being addressed by r16
(which is being copied into the EEADRL register, and is showing up there
correctly).
Re: [AVR-Chat] *oh*
Thanks John!  That sbi instruction was the culprit.  I misunderstood,
and thought that was only necessary if one was worried about the 4 clock
cycle delay in reading EEPROM.   *sigh*
tom
> i
Re: [AVR-Chat] *oh*
> correctly).
 And I think you just found out why :)
