AVR-Chat
Re: [AVR-Chat] *HAHAHA*
2007-01-18 by John Samperi
At 03:27 AM 19/01/2007, you wrote:
> > That is why I have adopted the practice of installing a
> > full vector table, with all the standard labels and filling
> > the unused ones with RETI or jump to an error handler.
A practise that I have also adopted. With the AVR I have developed
interrupt vector and interrupt service routines files for each type
of processor that I use. With the vector file I only need to .include
the file into my multi file projects without changes. Following the
problem a well know member of this list had with jmp and rjmp :) in
the table I simply copy the vectors from the data sheet, add a ISR_
keyword to each vector and save it. (so far the pdfs used are not
copy protected) ie (part of the int_v_tiny2313.asm file)
;Reset and Interrupt vectors Tiny2313
.cseg
;0x0000
         rjmp    RESET                   ;Reset Handler
;0x0001
         rjmp    ISR_INT0                ;External Interrupt0 Handler
;0x0002
         rjmp    ISR_INT1                ;External Interrupt1 Handler
The standard interrupt service routines have been styled on examples
found on David's old web page when I was first looking at the AVR.
(part of the int_s_tiny2313.asm file, save_sreg is usually r15)
;REMEMBER to save any registers you may want to use here!
;Int. flags are automatically cleared.
.cseg
ISR_INT0:
         in              save_sreg,SREG          ;Save Status register
;Do something here
         out             SREG,save_sreg          ;Restore Status register
         reti
ISR_INT1:
;Do something here
all I need to do with the service file is to copy it into a file
which is specific to the project and then either copy code from
another project or write handlers for the project. ie the
int_s_tiny2313.asm file would be copied to int_s_projectname.asm file
and massaged as necessary.
Using multiple files in your project has the advantage of not having
long files clogging up your screen and they are also easier to manage.
John Samperi
Ampertronics Pty. Ltd.
11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
Tel. (02) 9674-6495       Fax (02) 9674-8745
Email: john@ampertronics.com.au
Website  http://www.ampertronics.com.au
*Electronic Design * Custom Products * Contract Assembly
2007-01-18 by np np
I go a bit further with this method and use a previous project as a template.
I often find myself having the same subroutines in a lot of programs.
This has the advantage of having fully tested code already written.
http://www.ckp-railways.talktalk.net/pcbcad21.htm
John Samperi <samperi@ampertronics.com.au> wrote:                                  At 03:27 AM 19/01/2007, you wrote:
 .cseg
 ;0x0000
 ;0x0001
 ;0x0002
 .cseg
 ISR_INT0:
 ;Do something here
          reti
 ISR_INT1:
 ;Do something here
 John Samperi
 New Yahoo! Mail is the ultimate force in competitive emailing. Find out more at the Yahoo! Mail Championships. Plus: play games and win prizes.
2007-01-18 by Roy E. Burrage
You can do the same thing by writing program modules that are generic in
nature.  After a while you have a library of modules that can be
messaged for a particular application as John stated.  That Dave Van
Horn guy taught a lot of us some good basic proceedures...even though we
may have worked with some of the older 8035/8048/8032 series chips.
REB
> .cseg
> ;0x0000
> ;0x0001
> ;0x0002
> .cseg
> ISR_INT0:
> ;Do something here
>          reti
> ISR_INT1:
> ;Do something here
> Regards
> John Samperi
>Yahoo! Groups Links
2007-01-19 by Micro Brix
Gawrsh.. :)  Can I put that on my resume?
