AVR-Chat
C Code weird behaviour help?
2007-01-27 by luthjej
Hi all,
 I'm hoping someone may be able to offer some assistance to a weird
"C" behavior problem I'm having (ICC v7).
The target platform is a Mega16.
The problem I've simplified below - basically the code below does not
work, the two while loops (outside of the main "infinite" loop) are
supposed to alternate depending on the value assigned to "val"
(greater than or less than 650), however when using the variable
comparison - the loop never finishes (i.e. (otherval < val) is always
TRUE, regardless of the value applied to the "otherval" variable).
Confusingly (for me, at least :) - If I substitute the actual integer
in place of "val" in the while loop test statement - it all works fine.
Thanks in advance for any help ... this one has me stumped!
Jon
Code that doesn't work:
main ()
  unsigned int val;
  unsigned int otherval;
val = 650;
while (1)
   while (otherval < val)
     otherval++;
   while (otherval >= val)
     Do_other_stuff();
Code that DOES work:
main ()
while (1)
   while (otherval < 650)
     otherval++;
   while (otherval >= 650)
     Do_other_stuff();
RE: [AVR-Chat] C Code weird behaviour help?
2007-01-27 by Cat C
maybe you should be more specific about "int"... like "uint_8t", "uint_16t"
etc.
I may have gotten the actual names wrong, but U get the idea (I hope).
Good luck.
Cat
----Original Message Follows----
Reply-To: AVR-Chat@yahoogroups.com
Subject: [AVR-Chat] C Code weird behaviour help?
Date: Sat, 27 Jan 2007 06:24:58 -0000
Hi all,
Jon
main ()
   unsigned int val;
val = 650;
while (1)
      otherval++;
      Do_other_stuff();
main ()
while (1)
      otherval++;
      Do_other_stuff();
Yahoo! Groups Links
Buy, Load, Play. The new Sympatico / MSN Music Store works seamlessly with
Windows Media Player. Just Click PLAY.
http://musicstore.sympatico.msn.ca/content/viewer.aspx?cid=SMS_Sept192006
Re: [AVR-Chat] C Code weird behaviour help?
2007-01-27 by Dave Hylands
> main ()
>  unsigned int val;
> val = 650;
> while (1)
otherval is currently uninitialized and will take on some random value
from the stack.
> main ()
> while (1)
otherval is still uninitialized. The fact that it works is pure luck
Dave Hylands
Vancouver, BC, Canada
http://www.DaveHylands.com/
Re: C Code weird behaviour help?
2007-01-28 by luthjej
Thanks for the reply, Dave
Unfortunately the code snippet below is not the "real" code, but a
quick throw-together to illustrate the problem I'm having.
In the real code, the variables are initialized with real data.
Either statically (for testing) or dynamically from a pre-defined
location in EEPROM.
ICC actually initializes the value to 0 automatically as part of the
compile process anyhow ...
I'm still having no luck trying to solve this problem - might try and
use a series of if-then-else handlers instead of the alternating
while loops ... hmmm ...
Thanks again for the reply.
Jon
--- In AVR-Chat@yahoogroups.com, "Dave Hylands" <dhylands@...> wrote:
> Hi,
> > main ()
> >  unsigned int val;
> > val = 650;
> > while (1)
value
> from the stack.
> > main ()
> > while (1)
> Dave Hylands
RE: [AVR-Chat] Re: C Code weird behaviour help?
2007-01-28 by larry barello
Which compiler are you using?  AVR-GCC compiles and runs your code
correctly.
I'll state this again just for the benefit of all those who assume they
can't use GCC because it is too difficult: Studio 4 with the GCC plug in
makes is brain dead simple:  Just create a project, cut the code from the
email and paste into the initial file, and press the compile button.  Start
debugging, and see that it works.
If you set the compile options for anything other than -oO (default, no
optimization) the compiler correctly identifies the problems and warns you.
GCC is the best and only free compiler!
From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf
Of luthjej
Sent: Sunday, January 28, 2007 5:00 AM
Subject: [AVR-Chat] Re: C Code weird behaviour help?
location in EEPROM.
Jon
> Hi,
> > main ()
> >  unsigned int val;
> > val = 650;
> > while (1)
value
> from the stack.
> > main ()
> > while (1)
> Dave Hylands
Yahoo! Groups Links
2007-01-28 by John Samperi
I must agree with that even though I don't use C, no
make file to write up or other confusing stuff. The only
confusing bit for me is C itself... :) Perhaps the new
Studio 4.13 will make it even easier to use just like
the assembler.
John Samperi
Ampertronics Pty. Ltd.
11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
Tel. (02) 9674-6495       Fax (02) 9674-8745
Email: john@ampertronics.com.au
Website  http://www.ampertronics.com.au
*Electronic Design * Custom Products * Contract Assembly
