Re:Tiny2313
2007-02-14 by Mark Weston
Thank you everyone for your responses. As it happens I have a 10mhz crystal across 4 and 5 on the PCB already, with attendant 18pf caps to GND. I'm going to remove the crystal and try the AVRDUDE command line fix, that looks like the best at this point. If that doesn't work, I'll try the signal injector. Thanks again, and have a great day. Say, the cause of this whole nightmare was my attempt at getting an LCD working correctly from the 2313. Sadly though, when I plug in the LCD I just get the first line showing as a set of 16 black squares. My connections are RS @PB2, E @ PB3, DB4 @ PB4, DB5 @ PB5, etc. I'm using Bascom to program and I've used the Config LCDPIN statement to set up how the LCD is connected, but I get the dark line stuff right from the start, even before I programmed the chip, so I suspect there's something else afoot here. GND is connected, VCC is 5v, contrast runs to a 2.2K to GND. Pin 5 to GND. Any thoughts on where to look here. Oh yes, the LCD is a 5v 44780 standard 16x2 LCD with a 5v contrast. Mark Weston --------------------------------- Now you can have a huge leap forward in email: get the new Yahoo! Mail. [Non-text portions of this message have been removed]
