RE: [AVR-Chat] When boyscouts say one for all, all for one
2007-02-28 by Tim Mitchell
Leon wrote: > > RS-485 is one way. You could also daisy-chain the slaves and use the > UARTs, with each slave passing the message onto the next. You will > need some sort of addressing system; when the correct slave > identifies the message, it performs the desired action otherwise it > passes it on to the next slave. No, RS485 is not one-way, each node can transmit or receive. You are thinking of RS422 which has separate inputs and outputs. -- Tim Mitchell tim@sabretechnology.co.uk http://www.sabretechnology.co.uk Sabre Technology (Hull) Ltd, 3a Newlands Science Park, Hull HU6 7TQ t:01482 801003 f:01482 801078
