On 3/23/07, David Appleton <englsprogeny@yahoo.com> wrote:
> I could get my hands on a scope..... this sounds a little scary.
I would, if I were you.
Depending on the scope, you can get a LOT of information.
At one point, I was working on a battery charger, and I needed to know a
bunch of parameters, basically what mode it was in, and what the analog
readings were, and what decisions it was making, and why, so I wrote up a
routine I call "pong" (ping was taken) which outputs a byte as wide (1) and
narrow (0) pulses, so that no matter what the byte value is, the total width
is always the same. Using my DSO, I was able to read out 20+ bytes of
information that way. I'd have used a serial port, but I didn't have one
available, and you don't always have the uart pins free anyway.
The other thing that is very useful is a logic analyzer. I use an ANT-8,
that gives me limited buffer capacity, but down to 2nS capture. It just
dosen't do analog.
