AVR-Chat
Using the ADC to measure the battery supply?
2007-06-18 by Richard Cooke
Hi Folks,
I'm using the ATmega48V in a project and I need to monitor the battery
level (2 AAA cells) every so often and when low give an indication to
the user that it's time to change them.
I'm trying to minimize current consumption and I'm using the internal
1.1V reference so I'm using a voltage divider 1M + 3M to bring the
signal down to below the 1.1V reference.  I don't care how long the
conversion takes as I'm only making the measurement every 10 minutes
or so.
Do I need to use a buffer between the divider and the input to the
ADC?  If I do, what small, cheap and low power chip would you recommend?
Richard Cooke
Re: [AVR-Chat] Using the ADC to measure the battery supply?
2007-06-18 by BobGardner@aol.com
I think you need to disconnect the voltage divider using an fet. The voltage divider will draw more juice than the avr in sleep mode! I assume you read the datasheet about the half dozen or so best ways to cut down on power consumption? (turn off a/d, turn off pullups, which sleep mode to use, etc)
To: AVR-Chat@yahoogroups.com
Sent: Mon, 18 Jun 2007 12:30 pm
Subject: [AVR-Chat] Using the ADC to measure the battery supply?
Hi Folks,
or so.
Richard Cooke
Yahoo! Groups Links
________________________________________________________________________
AOL now offers free email to everyone.  Find out more about what's free from AOL at AOL.com.
Re: Using the ADC to measure the battery supply?
2007-06-18 by kernels_nz
This is excellent advice from Bob, using a fet to connect / disconnect
the power supply to the voltage divider also means you can use lower
value resistors for the divider, I have had some issues with resistors
> 1M OHM. Not sure what the input impedance of the A2D pin on the
micro is, but you want to pick voltage divider resistor values that
are much lower to prevent the A2D pin from loading the voltage divider.
What I have done in the past in a similar situation is actually used a
Output Port pin to drive the top of the voltage divider directly, this
eliminates using an external fet and the voltage diference between the
port pin output and supply rail is minimal.
Hope this helps.
Cheers
Hein B
Auckland, New Zealand.
> From: Richard Cooke <rcooke@...>
> Hi Folks,
> or so.
> Thanks,
> Richard Cooke
Thanks folks for the quick replies.
I'm not going to worry too much about the current consumption while
the unit is turned on since the RF chip will be using 12 mA so 1 or 2
uA more won't kill me.   I'm just worried about the input impedance
affecting the ADC reading.
Richard Cooke
> Hope this helps.
> Cheers
> Hein B
> > From: Richard Cooke <rcooke@>
> > Hi Folks,
> > or so.
recommend?
> > Thanks,
> > Richard Cooke
> > Yahoo! Groups Links
2007-06-18 by Ralph Hilton
Forget the FET. 10M resistors are cheaper if the consumption is that critical.
The only buffer needed is a 0.1uF cap.
>From: Richard Cooke <rcooke@digitalwavelength.com>
>Hi Folks,
>or so.
>Thanks,
>Richard Cooke
Ralph Hilton
http://www.ralphhilton.org
C-Meter: http://www.cmeter.org
FZAOINT http://www.fzaoint.net
2007-06-18 by dlc@frii.com
Most microcontroller's ADC will not like a 10M load, the charge time will
be very high and not very accurate.  I have used a low power OpAmp to run
very high Z dividers into and the output of the OpAmp is nicely low Z for
that ADC to be happy with.  Its a few more pins and passive parts than the
FET but the readings tend to be more repeatable.
DLC
>> to use, etc)
> critical.
>>Hi Folks,
>>or so.
>>Thanks,
>>Richard Cooke
> Ralph Hilton
Re: [AVR-Chat] Re: Using the ADC to measure the battery supply?
2007-06-18 by David VanHorn
> > 1M OHM.
This is documented, the ADC inputs are not perfect infinite impedance
inputs with no leakage current.. You're best to feed them with a real
low Z source, and disconnect when not looking.
2007-06-19 by Ralph Hilton
>DLC
It isn't 10M if a cap is across it!
>>> to use, etc)
>> critical.
Ralph Hilton
2007-06-19 by dlc
If the cap is across it then the ADC might not get the correct voltage
either.  The ADC relies upon charging a cap inside the module.  That
relies upon a certain target RC charge rate, that charge rate also must
not exceed the current capacity of the pin.  You are playing a finicky
game by using a cap to boost the inrush current to offset the RC time
constant.  It might work under some circumstances but since the ADC
modules specifically states that you should only be using slowly
changing signals on the circuit with low-pass filters that would tend to
contra indicate using a bypass cap I think.  Have you used such a
circuit successfully before?
curious,
DLC
>>DLC
>>>>to use, etc)
>>>critical.
> Ralph Hilton
Dennis Clark          TTT Enterprises
www.techtoystoday.com
2007-06-19 by Cat
I'm also curious, but a cap IS a low pass filter.
Cat
To: <AVR-Chat@yahoogroups.com>
Sent: Monday, June 18, 2007 11:00 PM
Subject: Re: [AVR-Chat] Using the ADC to measure the battery supply?
> curious,
> DLC
RE: [AVR-Chat] Using the ADC to measure the battery supply?
2007-06-19 by Phillip Vogel
1) The concept here is that the 0.1uF cap is way larger than the input cap
in the A/D and will present a low impedance source to the input.
2) What do you mean by "a certain RC charge rate?" AFAIK, the slope has
nothing to do with the A/D measurement, other than to say that you want a
steady input voltage during the actual measurement.
3) How in the world could adding a cap across the A/D input cause the input
current to exceed the capacity of the pin? We're not talking about a voltage
doubler - just a simple low pass filter.
4) I have used such a circuit very successfully before.
Phillip
From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf
Of dlc
Sent: Tuesday, June 19, 2007 1:01 AM
curious,
DLC
2007-06-19 by dlc@frii.com
Depends, series or shunt?  Big cap or small?
DLC
> Cat
> From: "dlc" <dlc@frii.com>
>> curious,
>> DLC
2007-06-19 by Cat
The word "across" in your message I quoted means something to me.
Big or Small doesn't make a difference (still LPF, better or worse).
Sent: Tuesday, June 19, 2007 9:16 AM
> DLC
>> Cat
>> ----- Original Message -----
>>> curious,
>>> DLC
>> Yahoo! Groups Links
2007-06-20 by Ralph Hilton
On Mon, 18 Jun 2007 23:00:54 -0600 you wrote:
We are talking about a battery voltage indicator needing 3 bits resolution max.
Lets get a bit more real here.
Keep it simple.
The original requirement was:
"I'm using the ATmega48V in a project and I need to monitor the battery
the user that it's time to change them."
Some of the points mentioned are possibly relevant for much higher resolution
and accuracy but the requirement is a simple indicator to tell the user to
change the battery !!!
>curious,
>DLC
>>>DLC
>>>>>to use, etc)
>>>>critical.
Ralph Hilton
2007-06-20 by Darren Worley
Finally, someone read the actual task, and come back to reality.
It's great to see discussion on such topics, but sadly, us techies can get
so tied up in the design intricacies at times, we really need to keep
focused on the end goal and stay in perspective. Albeit, its fun at times to
get sidetracked ;)
  _____
Of Ralph Hilton
Sent: Wednesday, 20 June 2007 10:14 AM
max.
Keep it simple.
resolution
>curious,
>DLC
>>>DLC
assume
>>>>>to use, etc)
>>>>critical.
Ralph Hilton
http://www.ralphhil <http://www.ralphhilton.org> ton.org
C-Meter: http://www.cmeter. <http://www.cmeter.org> org
FZAOINT http://www.fzaoint. <http://www.fzaoint.net> net
2007-06-20 by David VanHorn
> get sidetracked ;)
Before you think that the offset current is a sidetrack, I suggest you
look at the magnitude of that current, against the megohm-range values
of resistors that were suggested, and the real active range of a
battery measurement done that way, (in bits)then tell me that it's
irrelevant.
