AVR-Chat
buffer
buffer
2007-06-20 by magzky02
Hello guys.. I have an application where in the output pin has a
greater posibility being shorted to VCC. Now when this pin is set low,
it causes high current. To avoid this, i am thinking of placing a
buffer after the output pin (i dunno if this is the best idea, i
appreciate feedbacks). I am searching the farnell and i saw some
LVC07A from TI. Can anyone can recomend a similar device with only a
single (or two) buffer in it? running from 1.7 to 3.3 VCC..
regards,
mago
Re: [AVR-Chat] buffer
2007-06-20 by Ned Konz
What are you driving? How fast? How big a load? The LVC07A is open
drain, right? Do you need to source current too?
There are high-current "low-side FET" or relay drivers available in 1-
and 2-driver packages. Some are overload protected.
Then there's the automotive P-FETs with current limiting, but these are
probably much higher current than you need.
If you're looking at using an LVC07A, you should consider the
single-gate "tiny logic" drivers.
2007-06-20 by David VanHorn
There's a lot of unsaid things here, even a series resistor might
work, depending on what you're doing with the pin.
2007-06-20 by Ralph Hilton
On Wed, 20 Jun 2007 09:43:47 -0000 you wrote:
What does the output pin normally drive? How does it get shorted to VCC?
>regards,
>mago
Ralph Hilton
http://www.ralphhilton.org
C-Meter: http://www.cmeter.org
FZAOINT http://www.fzaoint.net
2007-06-20 by mago Umandam
A series resistor was my first solution but it didnt work because of the the 49 Ohm pull up resistor at the other end of the line. when the uC pin set the line low, the output voltage will become a voltage divider and is quite high unless i will use a very low series resistance (compared to 49) which will defeat my purpose. I can not change the 49 Ohm pullup resistor at the other end because it is another system i just want to control.
regards
mago
David VanHorn <microbrix@gmail.com> wrote:                                  There's a lot of unsaid things here, even a series resistor might
Building a website is a piece of cake.
Yahoo! Small Business gives you all the tools to get online.
Knowing this, I'm wondering why you don't use a 2N7000 or similar
mosfet as a buffer.
It will crank that line to ground, and draw essentially no current
from the AVR while doing it.
2007-06-20 by kholt@sonic.net
You might consider leaving it as is. Most of the AVRs can take
a short to VCC without killing the device. Is the short likely
to happen during development, or in use? Short or long time?
With or without a buffer, a short will cause loss of functionality
during the short; you may find the risk of permanent damage is higher
with the buffer - the current and heat will be higher.
Ken
> regards,
> mago
2007-06-20 by John Samperi
The first thing is to try and remove the possibility of shorts
to VCC.
Is the resistor tied up to 5V at the other side? That would be
a 100mA sink you are trying to get from a pin!! Even at 3.3V it is
still about 70mA. Then you have to consider the possibility of having
you board powered off and the other powered on (maybe it can't happen??).
As a minimum I would fit an open connector (drain) driver and perhaps
even a small fuse.
John Samperi
Ampertronics Pty. Ltd.
11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
Tel. (02) 9674-6495       Fax (02) 9674-8745
Email: john@ampertronics.com.au
Website  http://www.ampertronics.com.au
*Electronic Design * Custom Products * Contract Assembly
Checked by AVG Free Edition.
Version: 7.5.472 / Virus Database: 269.9.1/854 - Release Date: 19/06/2007 1:12 PM
