AVR-Chat
USB interfacing
USB interfacing
2007-08-27 by antdi25
hello friends,
i want to use USB for interfacing some basic testing
hardware like LED,LCD or keypad etc.but i don't know anything about
USB interfacing. For example ,i want to interface led using USB
power.How can i do it? & what type of software tool i will need for this?
please give me idea,if anybody know about it.
thanxs & regards
ankit
Re: USB interfacing
2007-08-27 by John
Just a thought, try the USB Organizations web-site:
http://www.usb.org/developers/docs/
Has all the technical specs for USB, this will provide the underlying
technology and some of the terminology.  Effectively, you have several
options for your device: 1) you can implement an already defined
device class (for example, a virtual serial port,) or 2) define your
own class.  Option 1 removes the need to write host drivers for the
devices.
Then, you can look at your micro-controller (assuming AVR, as that is
the forum's specialty,) and read through it's documents.  Most
microcontroller shops offer app notes or the like on implementing some
of the basic device classes, these would make a good starting point
for the microcontroller side of the project.
If you opt to make your own device class, you will need to write your
own host side drivers.  If you are using MS Win32, you will need the
Device Development Kit (DDK) from Microsoft.  If you are using Linux
or Mac OS, you should be able to use LibUSB.
John
--- In AVR-Chat@yahoogroups.com, "antdi25" <antdi25@...> wrote:
> hello friends,
this?
> thanxs & regards
> ankit
Re: [AVR-Chat] USB interfacing
2007-08-27 by Zack Widup
There are msny products available for USB interfacing.  Just do a Google
search for "USB interface".
Here's one:
http://www.hobbyengineering.com/SectionIN.html
For $33, the USB232R looks like a great deal. This is one example of many
you can find with a search.
Zack
On Mon, 27 Aug 2007, antdi25 wrote:
> hello friends,
> thanxs & regards
> ankit
2007-08-27 by Kurniawan Dian
hi antdi25,
try this,
http://www.obdev.at/products/avrusb/index.html or
http://www.cesko.host.sk/IgorPlugUSB/IgorPlug-USB%20(AVR)_eng.htm
or
http://www.xs4all.nl/~dicks/avr/usbtiny/
regards
Dian
--- antdi25 <antdi25@yahoo.co.in> wrote:
> hello friends,
> anything about
> led using USB
> thanxs & regards
> ankit
Shape Yahoo! in your own image.  Join our Network Research Panel today!   http://surveylink.yahoo.com/gmrs/yahoo_panel_invite.asp?a=7
RE: [AVR-Chat] USB interfacing
2007-08-28 by Mujahidin
If you want to use pure usb communication you will spend your long time.
Because the usb protocol is very completely. In this millist is often
discuss about the usb communication, and the real solution for your problem
and you will spend short time is you can use usb to serial converter chip
(Maxim, philips and much more)
Or you can also use The Microchip microcontroller like PIC18F4550 (Support
with USB2.0 USB 1.1 and USB 1.0) , on this chip you can emulate RS232 over
USB with the template available on the microchip website. You can modify the
template as you want, you will look this very nice..
iddhien (http://iddhien.com <http://iddhien.com/> )
  _____
From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf
Of antdi25
Sent: Monday, August 27, 2007 3:16 PM
To: AVR-Chat@yahoogroups.com
Subject: [AVR-Chat] USB interfacing
hello friends,
thanxs & regards
ankit
2007-08-28 by Alex Shepherd
> hello friends,
> about USB interfacing. For example ,i want to interface led
> using USB power.How can i do it? & what type of software tool
Have a look at this website:
http://www.obdev.com/products/avrusb/index.html
I have assembled a version with a Mega48 to do USB to TTL 3.3V UART serial
and it seems to work ok if I connect it directly to the USB port on my
notebook but it won't work with a USB hub :(
YMMV
Alex Shepherd
Re: USB interfacing
2007-09-03 by antdi25
Thanks to all friends for help me by given such a good information.It
can be very useful for me to do my work easily.
thanks & regards
ankit
problem
chip
(Support
RS232 over
modify the
> Regards,
>   _____
Behalf
> Of antdi25
> hello friends,
this?
> thanxs & regards
> ankit
