AVR-Chat
Dragon Rider - opinions and field tester wanted
2007-09-13 by Graham Davies
I am working on a new product intended to make the AVR Dragon as easy
to use and as flexible as the old STK500.  Briefly, it is a PCB that
sits on top of the Dragon and has the familiar target microcontroller
area, 10-pin headers and other useful gadgetry.  With it, you can use
your Dragon for prototyping various circuits without the ridiculous
soldering-on of a ZIF socket in Atmel's microscopic "prototyping
area".  Here is the detailed informatio in draft:
http://www.ecrostech.com/AtmelAvr/DragonRider
I would be interested in general opinions on this product,
specifically, of course, would it sell?  I expect the bare PCB to be
priced at about $8 and the parts kit at about $17.  It is a goal that
the AVR Dragon and the complete Dragon rider cost less than the
STK500.
If anyone is so interested that they'd like to reserve one when I go
into production, please let me know.
Finally, I have a prototype that I'd like someone to subject to field
testing.  You'll need your own AVR Dragon, a selection of the
supported microcontrollers and some 10-way ribbon cables from the
STK500, but I'll send the prototype kit at no charge and at my
expense.  I'd prefer you to be in the USA, but I'll go the extra
distance for an established AVR expert.
What I'm hoping to learn is this:
* Can the Dragon Rider be assembled with normal skill?
* Does it function as advertised?
* In what ways could it be improved, while keeping to the basic
purpose?
* What auxiliary functions (buttons, LEDs, etc.) would be useful?
Here are a few things I already know about:
* Getting the single-row headers straight is difficult, but I can't
figure a way around this while leaving room to get the shunts on and
off with just fingers.
* I'm supplying a 150 ohm resistor for the 100 ohm resistor.
* There is a footprint for a large supply decoupling capacitor, but
in my testing it seemed to be a bad idea so I intend to remove it.
* You'll probably wish there was a power switch instead of a jumper
when you test debugWIRE.
* The light guide isn't quite above the Dragon LED.
* The reset line de-glitch capacitor is not supplied as I haven't
found it necessary.  I should probably try it out anyway (so many
combinations!).
The first field tester reported this:
* There should indeed be an on/off switch for the target area.
* Yes, the light guide isn't quite above the Dragon LED.
* An RS232 level converter and connector would be nice.
If you don't want to reply in this thread, there's a contact page on
my Web site.  Thanks for reading.
Graham Davies
www.ecrostech.com
Re: [AVR-Chat] Dragon Rider - opinions and field tester wanted
2007-09-13 by John Samperi
You may know of the impending arrival of the STK600 I suppose,
we will know more of it's capabilities as soon as the first AVR
seminar hits the road in the US shortly.
May be you are aware of this thread on AVRFreaks:
http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=53368&highlight=dragon
I have a ZIF socket with my Dragon but only used it once,
I have a myriad of boards with many types of AVRs so it is not
something I would buy, I guess it would be something that a
beginner may want to use. I don't even use the STK500, only
occasionally for the odd HVPP or to help someone with a problem.
Just my 2c...
John Samperi
Ampertronics Pty. Ltd.
11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
Tel. (02) 9674-6495       Fax (02) 9674-8745
Email: john@ampertronics.com.au
Website  http://www.ampertronics.com.au
*Electronic Design * Custom Products * Contract Assembly
2007-09-13 by David Kelly
Having just recently fired up my Dragon, the most useful thing missing
would have been a selection of 3" jumpers color coded to the tables in
the Dragon manual. And having the big 40 pin header loaded.
A cable with ISP plug on one end for my target, jumper plugs on other
for the Dragon would also be nice.
Next most useful would be a PDF version of the current Dragon manual.
I put machine pin strips in the 28 pin "socket", and will do same for
the 40 pin socket if need arises.
I goofed and didn't put a full ISP header on my target board, only a 3
pin DebugWire connector. After soldering the ATmega48 discovered my
goof. Pre-conditioned a few chips in my socket on the Dragon, cut some
traces on my target board and got ISP control over that chip to flip it
into DebugWire mode.
David Kelly N4HHE, dkelly@HiWAAY.net
Whom computers would destroy, they must first drive mad.
Re: Dragon Rider - opinions and field tester wanted
--- In AVR-Chat@yahoogroups.com, John Samperi <samperi@...> wrote:
> You may know of the impending arrival of the STK600 ...
My impression is that the STK600 will be priced much higher than the
STK500 and AVR Dragon.  If the AVR Dragon has a place out there, the
Dragon Rider may have one too.
Well, that shows that people do want something to make the AVR Dragon
more flexible.  I wish the guy the best of luck with his two-part
solution, but there's more to bringing a product to market than
designing a PCB.
> ... I guess [the Dragon Rider] would be something that a
Maybe.  I think it could be useful to anyone who wants to put an AVR
through its paces and is staring at their AVR Dragon thinking "what
now?".
Graham.
2007-09-16 by Eric Engler
I love the idea of a module like this but what I really want to see if
enough peripherals to make this a good educational platform. For
example, maybe some I2C ports like RTC or Temperature, and some A/D
peripherals such as a POT. Since my idea is to use this for
educational purposes the specifics of the peripherals aren't critical
but they need to be stardard so each board will have the same stuff.
I try to help college students occasionally and the biggest problem
with designing demo programs for them is that there are not well
defined standard hardware boards that common peripherals and also ICD.
They like ICD because it helps them understand the internals better.
The Dragon has ICD but no standard peripherals. Of course we'd have to
agree on one specific MCU, and then a standard set of peripherals that
would allow us to write good demo programs that will work "out of the
box".
There's a steep learning curve that can be minimized with this type of
board-level product.
But they'd also have to be avalable in a pre-assembled format to be
useful to most college students because they usually don't have enough
time in their schedule to assemble their own boards. They will have
some classes that teach that skill but their MCU class is normally not
structured to allow lab time for this purpose.
Eric
Re: [AVR-Chat] Re: Dragon Rider - opinions and field tester wanted
2007-09-16 by David Kelly
Would be an interesting program if one term the students designed, layed
out, and built their own boards. Maybe program them the next term.
Low volume PCBs are very reasonable these days, double sided, plated
holes, soldermask, and silkscreen.
If the students are going to do embedded work for a living, these are
things they are going to have to know.
Clearly there is room for improvement in school curricula.
Re: Dragon Rider - opinions (field tester all lined up)
2007-09-16 by Graham Davies
--- In AVR-Chat@yahoogroups.com, "Eric Engler" <englere.geo@...> wrote:
> ..  what I really want to see is
Well, actually, the Dragon Rider isn't supposed to be just one
product.  I'm starting with what will probably be the Dragon Rider 500
(because it attempts to be like the STK 500), but I've been thinking
also about Dragon Riders for just a single type of MCU that are more
for building actual projects on.  These would be suited to educational
purposes.  The AVR Dragon would be re-usable and the Riders would be
semi-disposable.  Students could purchase them and keep the projects,
which would of course work without the Dragon.  One of the people who
contacted me about the field test is interested specifically in this
type of application.
> in a pre-assembled format ...
Most of my stuff is offered bare PCB, PCB with kit and assembled.  For
large orders that I know are coming I can reduce the price of assembled
product by having someone else do it.
And, David Kelly wrote:
... students designed, layed out, and built their own boards ...
program them the next term ... Low volume PCBs are very reasonable ...
these are things they are going to have to know ... room for
I agree that this would all be very nice, but it just may not be
feasible to get all students through this in the available time with
the available supervision.  There are a heck of a lot of minor (and
boring) issues to take care of in this process that we geezers take in
our stride but can baffle newcomers.  Also, engaging the student is
very important and that's much easier to do when the hardware is
sitting there waiting to be programmed.  It makes more sense to me to
have the student build their own project as you suggest *after* they've
messed about with some pre-constructed gadgetry and have a clearer
vision of where it will all end up.
Graham.
Re: [AVR-Chat] Re: Dragon Rider - opinions (field tester all lined up)
2007-09-16 by David VanHorn
I agree..  A completed board, with some interesting sensors and output
devices, with well-written code that works, would be a big plus.  It's
always easier to start off by modifying something that works, than to
learn all the twitchy details first.
2007-09-17 by Roy E. Burrage
...And then have to listen to a bunch of old farts tell us "Oh yeah, I
had a problem with that when I was just getting started."   8-)
It seems that no matter how much detail we try to provide to someone
who's new to AVRs, there's always something that gets overlooked.  But
that's just more reason to keep Dave VanHorn's getting started with the
AVR code handy.
REB
2007-09-17 by David VanHorn
> AVR code handy.
:)  That's still out there I guess.
I feel bad that I haven't updated it in ages.  I should probably do a
M128 port or something like that, maybe add some new peripherals.
I've been working with a few new sensors lately, but not something
that you'd want to put on a student board, too pricey and complicated.
There are a couple of things I'd like to see done, like dynamic memory
allocation, and efficient string parsing.  My current app looks for a
number of command strings in a serial input stream, and although it
works well enough, it's rather "klunky".   I haven't hit any
inspirations on a better way to do it yet.
2007-09-17 by Hans Kallen
Here's another approach I took for providing a flexible experimental
and educational platform for the AVR:
http://www.avrcard.com/products/playground_overview.htm
Maybe you can use some of these concepts for your work.
Hans
2007-09-17 by Graham Davies
--- In AVR-Chat@yahoogroups.com, "Hans Kallen" <hk@...> wrote:
> ... another approach ...
Some of my ideas are similar to what you've done, for example, the
little plug-on boards that pick up one of the expansion busses.  I want
to steer clear of other people's work to add a new option to the AVR
community and "make the pie higher" rather than fight for a share of
someone else's slice.  For example, the university that expressed an
interest in trying out the Dragon Rider is moving to AVR from PIC.  The
Dragon itself, of course, does not support on-chip debug with the
larger memory AVRs such as the AVRcard uses.
Graham.
2007-09-17 by Eric Engler
We can't use a Dragon for ICD on an ATMega128, right?
Eric
Re: Dragon and ATmega128
2007-09-18 by Graham Davies
Right.  32K limit.  But, as the ATMega128 is supported by the old
JTAGICE, you can use one of the JTAGICE clones, such as the AVR ICE-
Cube, for an inexpensive solution.
Graham.
Does anyone have STK 500 for sell it????
2007-09-20 by alfred salazar
Plz let me know I need it for school project
  Thnx!!!
Alfredo
  aesv@yahoo.com
Alfred Salazar
Catch up on fall's hot new shows on Yahoo! TV.  Watch previews, get listings, and more!
RE: [AVR-Chat] Does anyone have STK 500 for sell it????
2007-09-21 by Ricardo Callejo
Check Ebay.
Ricardo Callejo
SURbyte SRL
Argentina
  _____
De: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] En nombre de
alfred salazar
Enviado el: jueves, 20 de septiembre de 2007 17:31
Para: AVR-Chat@yahoogroups.com
Asunto: [AVR-Chat] Does anyone have STK 500 for sell it????
Thnx!!!
Alfredo
aesv@yahoo.com <mailto:aesv%40yahoo.com>
Alfred Salazar
and more!
  _____
E-mail clasificado por el Idenfificador de Spam Inteligente. Para modificar
la categorma clasificada acceda a su webmail
  _____
Este mensaje ha sido verificado por el E-mail Protegido. Antivirus
actualizado en 20/09/2007 / Versión: 5.1.00/5124
Re: Dragon Rider - Product Announcement
2008-01-11 by Graham Davies
> to make the AVR Dragon as easy to use
> and as flexible as the old STK500 ...
Well, after sifting through feedback from field testers and a lot of
difficult compromise, I have the Dragon Rider ready for sale.  You can
read about it here:
In the end, I had to split the functions people wanted into "add-on"
kits so that the "buy-in" price met my goal of $25.  Also, nobody
reported using High Voltage Programming, so the parts for that don't
come in the basic kit.  As a result, the PCB and basic kit are $23.95.
At the last minute, I decided that perhaps not everyone wants, or even
groks, the full complexity of the Dragon, so I added a "Quick Start"
kit to allow beginners to get their Dragon up and running quickly at
minimal cost.  (If you order this, there may be a bit of a delay as
there's some kind of holdup where I ordered the microcontrollers.)
Thanks for the feedback and thanks again to the field testers.
Graham Davies
www.ecrostech.com
