I feel a little proud that you want some Tips for this Evolvertracks ...
2007-02-12 by octraboy
I use Soundiver to edit the Evolver the add for Sounddiver is on Daves Homepage... Sync the Evolver to Midiclock and record it as a Audiofile in a Sequencer like Logic,Cubase, Samplitude etc...while it runs in Sync...sometimes i tweak it sometimes not i use here and there Outboard Fx on this Evolvertracks. Its very important to use a Editor for the Evolver cause this Beast must be controlled...i dont like the most Presetsounds there are for me allmost useless cause they Sound often so Distorted... The Evolver is a very complex Synth then you will understand this Synth much better as when only tweak around with the Knobs... When record Audio you got no more Midiproblems like Controllers etc. and it doesnt matter if its a Monosynth or not.You can record endless Tracks now... Ive done Years with Midi but today i use it only to play in then i record it when it fits to Audio this is the much better Way for me .Plugins etc... to add special Fx when needed and so on... i use both Worlds to push it forward Analog and Digital. But to record Audio without a Timingproblem/Good Quality you need a fast and Good Asio Soundcard and a Analog or Digitalmixer with a Severaloutput . When not you will have Feedbackproblems when listen and record at the same Time... I use a ESI Juli Soundcard its cheap but Good Quality and a Mackie Mixer cause they have this Genius Alt 3/4 Severaloutputs and there cheap but Good..But of course you can use any other Fine Equipment to doing so,a good working Audio Computer is the Basic for working this Way. Thats all Regards Johannes
