P08 Discussions
2007-09-24 by arglebargleuk
Is it OK to talk P08 here? I'm having a lot of fun with mine but there are a few things I'd like to understand better. Mostly related to the sequencer - I'm trying to work out whether it works in an absolute or relative way. Say you sequence resonance, does each step set the absolute resonance overriding the ordinary res setting completely? If it were relative I'd expect positive and negative modulation amounts. I find that it seems to be a mixture of absolute and relative cos the resonance control still works whilst being sequenced... Anyone know the answer? Similarly, I can sequence VCA level but this doesn't work like turning the VCA level control. The control appears to apply to all notes, the sequencer sequences individual notes - so when you set values that way followed by values of zero, the zero doesn't silence ALL held notes. Does that make sense? Cheers, Paul
