DT Express II Configuration - Help me with this one, somebody!
2004-10-11 by jggallow
Let me give you the before and after on my mission here.
I just bought a Pintech Zenbal single zone High Hat to replace the
TP65 Yamaha pad that came with the set (I didn't like the unnatural
feeling and shape of the TP65). I now want to use the TP65 as
another Tom.  Currently, Input 9/10 is being used for another Crash
cymbal I bought separately.  Hence, all of the inputs behing the
module are populated.  Because the end result of this upgrade is
that I've added one pad to my configuration, the only place it can
plug into is the input jack on the KP kick pedal.  The instructions
say to utilize that, a cable from the output on the KP MUST connect
to Input 9/10 on the module.  To do this, I must now unplug the KP
cable from Input 1 and move it to Input 9/10 to get that extra Tom
working.  However, that also means I have to unplug the current
crash cymbal in Input 9/10.  I still want to use that as well, but
the only available Input now is Input 1 (the now-empty labeled Kick).
My questions are:
1.  How do I permanently "remap" Input 1 (labeled Kick) to now be a
Crash Cymbal.  By permanent, I don't mean just creating my own kit
and storing it as Kit #49 or #50.  I mean, if I chose to play kit
type "Big Reverb" the crash cymbal would make a cymbal noise - not a
bass drum noise that the module thinks is connected to it.  I'm sure
there's a way to do a permanent remap - I just don't understand how
to do it.
2.  I kind of know how to configure Input 9/10 now to be both a bass
drum and a tom, but I have the same kind of question.  How do I
permanently remap that configuration so if I chose to use a canned
pre-set kit type, like Big Reverb or Rock Dry 2, the module will
play a bass drum sound when I kick - not a Cymbal.
3.  My new Pintech high-hat is, out-of-the-box, very quiet and I
have to hit it hard to get a decent sound out of it.  How do I
manipulate that non-Yamaha cymbal to produce a nice heavy Hi-hat
sound without having to swing hard at it.
4.  I'm also getting a fair-amount of cross talk when hitting the
new hi-hat.  I'm hearing the newly added Tom (TP65) and the snare
drum as well when striking the Hi-hat.  I think there are some
rejection settings there that may work for this, but it's unclear.
