What is this "Magic Box" in the Pic's section? And what does it do?
Re: What is this "Magic Box" in the Pic's section? And what does it do?
2004-12-08 by zapaxe
--- In DTXpress@yahoogroups.com, "emf" <liberatusvirus@y...> wrote:
> --- In DTXpress@yahoogroups.com, "zapaxe" <a_zapelectric@h...>
wrote:
> > Is it a mixer? A switcher?...A Smoker & A Toker?:o
> Steve,
> Run a search of "magic box" in the archives.
> Ed
Ah! Thanks Ed,
I guess I should "search" things out a bit more as I've been
flooding this forum:o 'lol'
Ok, this "Magic Box" looks 'very' interesting! As I have 3 modules
and run the modules stereo outputs into the 6 CH mixer section from
my Tascam 246 4 track, I may not yet need one:) I still have pleny
O' trigger inputs to use up at this point...Just need MORE pads!
Maybe I missed something, but I'm a little unclear still about how
this 'Magic Box' actually is able to use the 'other' part of the
stereo trigger input in the DTXpress module..I 'thought' I read
something about resisters used.
I'll copy & paste below the best description I found in my "search"
for anyone else who's interested in the Magic Box;)
COPY/PASTE
[Ed,
One of the first two prototypes of the "Magic Box" is on its way to
OGB by arimail right now - in fact I would have hoped he would have
received it by now as it went on 25th November. Pictures are in the
photos/magic box section. It has eight inputs and four outputs and
allows you to add four pads which will then appear as the "rim" of
four inputs you use. A typical setup might be to use the three toms
and say a cymbal input to add another four inputs for cowbells,
chimes
or other additional sounds. The limitation is that both the rim and
main pad sound cannot be simultaneous so if you put a cowbell and
TOM1
through the box in to the TOM1 input, you will not be able to play
cowbell and TOM1 simultaneously (but very close together is OK).
It utilises the unused stereo inputs on all the DTXpress inputs. Even
the kick pad can take a three zone snare input. You could even add
two magic boxes if you got carried away.
Keith.]
2004-12-08 by Keith
All the "stereo" inputs want one piezo and a rim switch as input.
Without the rim switch you have just the main pad sound available.  If
you want to use two pads on one input, you can't because you have two
piezos and no rim switch instead of one piezo and one rim switch.
The "magic box" takes the two piezo signals and turns them into one
piezo signal plus a rim switch signal to fool the DTXpress box so it
thinks the signal has come from the centre or rim of a two zone pad.
It came about in response to a number of people asking why they cannot
use the unused rim capability of the DTXpress to add more pads instead
of buying another DTXpress box.
Hope that makes it a little clearer.
Keith.
how
available.  If
two
it
pad.
cannot
instead
> Keith.
Thanks Keith,
I only just saw this thing over last weekend, and what a great idea!
Are you planning on devoping this thing commercially, or just for
Sheets N' Keegles?
Yeah, I was 'one' of those who asked why I couldn't use the stereo
inputs with two single zone pads 'way back' when there was only a
DTXpress I kit. My question was explained at the time.
I suppose the "Magic" part of the box is a secret? Since you are the
creater of this "Magic Box" and if it is a secret, it's cool:) But
again, I thought I read that some kind of resister? (10K?) is used
to - shall I say - convert, or tag along an FSR like signal to the
modules 2nd part of the stereo trigger input. Maybe I read something
else though?...CRS!!!
Not near as crafty, but I had been thinking about building something
that 'looks' similar. Some kind of trigger input/output box.
Basically I guess just a glorified patch bay of sorts, as a way to
easily interchange the ins/outs of my trigger pads to my three drum
modules as needed. Then go a step further in the design by adding
switches on it so I can route the ins/outs 'without' actually having
to unplug and plug (as in a regular patch bay) my triggers jacks.
Just a thought though!
Note, since I DO have multiple modules that I've not yet got enough
pads to fill in all my trigger inputs as it is, I may not need a
Magic Box yet, but it's definately something I may consider at some
point...But hell, it sounds like a blast just experimenting with
it!:)
This excess of trigger inputs that I DO have, makes me want to
experiment in building some triggers & I'm thinking of different
unique ways to make these. I've seen some pretty crazy designs!
This also brings me back a memory as a kid of about 12? I made an
entire drum set, out of Folgers coffee cans. The cymbals were made
from the metal cut out lids, and the cans themselves were the drums,
the plasic top covers were the drum heads. Sounded like crap too!
["He,he"] I thought about revisiting this idea (as a novelty) but
with triggers put on them...But these days I drink Uban! 'lol'
Steve
2004-12-08 by Keith
Steve,
I plan to commercialise it if practical.  If there isn't enough
demand, or if it has limitations which would make it uncommercial, I
will publish circuits here and information so hobbyists can make their
own.  There is one trick which is required to make it work, so I have
filed a patent application for it, just in case!
The 10k resistor is used to get 2 rim sounds instead of just one.  The
DTXpress detects the resistance of the rim switch.  Theoretically I
could make the magic box have 12 inputs and 4 outputs but feedback
from this group suggested 8 in and 4 out would be a sensible number.
Keith.
wrote:
> > I suppose the "Magic" part of the box is a secret? But
used
 Steve,
I
their
have
The
number.
> Keith.
Sounds great Keith,
Yeah, being as greedy as I am, I was wondering why there was
not 'more' inputs myself - just how my mind works - Though 8 in 4
out is sensible, I'm wondering if the 12 in 4 out would be that much
more costly to make/sell?
I just now had a thought about my previous post about if something
like my glorified patch bay idea with the switchable out put
selection would be usful to build into something like your Magic
Box? Again, the switches was an idea to swap my triggers easily from
one module to another. Eh, maybe too complicated :/ ...If not I
won't be marketing 'my' idea btw ;)
I also had another thought last night to experiment with...At this
time I have 2 of my modules in operation with my kit and their
stereo outputs going to my small mixer, then out to my sound card
etc...
I don't know how this would affect this would have on the triggers,
but 'instead' of (I'll call it) my "super Patch-bay idea", has
anybody tried running the trigger pads directly into a mixer 1st,
then into a module or 2? I was thinking that I could use the panning
L/R part of the mixer to send the triggers signals outputs from one
module to another, or both modules if panned at the center...?
In fact I'm going to try the above. If it's something that's usful
to me, I'll look to buy some kind of small rack mount mixer...Or
I'll build some kind of custom job for the task. Though building a
mixer with levels and panning is above my skills, so...?
Steve
RE: [DTXpress] Re: What is this "Magic Box" in the Pic's section? And what does it do?
2004-12-08 by rdamon@mckinney-usa.com
Steve,
Did you ever see my cable management system that I had on my old kit. It had
a series of remote jack points (six points with 5 TRS jacks) that came back
to a central "hub" of 40 TRS jacks. The hub mounted just below the three
Dtxpress II modules. I then used 12" and 24" patch cords to connect the pads
to the remote jacks and 12" TRS cables from the central hub to the module.
If I wanted to switch a pad from one module to another, I just changed the
patch cables at the module. At one point I posted them at this group, but
removed them. I know they were posted at Vdrums and are still there. You
have to do a search under "cable management" I think to get to them. If I
ever get the chance, I may do something similar for my current kit. All the
internal cabling was TRS and all jacks were TRS.
OGD
   _____
Subject: [DTXpress] Re: What is this "Magic Box" in the Pic's section? And
what does it do?
selection
The information transmitted herewith is sensitive information intended only
for use to the individual or entity to which it is addressed. If the reader
of this message is not the intended recipient, you are hereby notified that
any review, retransmission, dissemination, distribution, copying or other
use of, or taking of any action in reliance upon, this information is
strictly prohibited. If you have received this communication in error,
please contact the sender and delete the material from your computer.
______________________________________________________________________
This email has been scanned by the MessageLabs Email Security System.
For more information please visit http://www.messagelabs.com/email
--- In DTXpress@yahoogroups.com, rdamon@m... wrote:
> Steve,
kit. It had
came back
three
connect the pads
module.
changed the
group, but
there. You
them. If I
kit. All the
> OGD
Hi OGD,
No, I didn't see that..I'm off to work, but I'll want to do
a "search" for it later and check it out for sure!
It think it sounds similar to what I was thinking, minus my idea of
installing switches to eliminate having to unplug the cables...?
I did build something similar before, but a much more simple design
for my guitar to switch between guitar amps. This was before I had a
rack-mount multi-FX unit with a multi-switch pedal that could switch
an almost unlimited amount of settings, volumes, distortions FX's
etc...So I dropped my home-made amp switcher!
Steve
2004-12-08 by Keith
Steve,
Be careful putting the triggers into a mixer - the piezos can generate
10V or more - may not improve the mixer input stage.
Keith.
2004-12-09 by zapaxe
...has anybody tried running the trigger pads directly into a mixer
1st, then into a module or 2? I was thinking that I could use the
panning L/R part of the mixer to send the triggers signals outputs
from one module to another, or both modules if panned at the
center...?
Steve,
generate 10V or more - may not improve the mixer input stage.
Keith.
Ooh, I didn't know that! I normally start levels at zereo when I do
things that may an adverse affect on my gear:0
But I may be better of with my "Super Patch-Bay" idea with selection
switches & "Y" capabilities as I don't actually need to "pan"
anything, just left to one module, right to another, or both!
Steve
