Adding on..
Adding on..
2005-09-29 by Alan Ault
Sorry guys if this has been covered a million times but I had a
question about adding other pads to my DTXPRESS III. I guess my main
objective is to have other pads to use mainly for cymbals. Looking at
the rear panel I do not see any extra inputs so I believe I need to
purchase some sort of uhh something! Where can I get something like
this? Thanks everyone!
Re: Adding on..
2005-11-04 by ewiget41056
On my dtxpress III, I added two additional cymbals (for a total of 2
crashes, a ride, and a china) plus an extra tom pad for a total of 4
toms by using stereo cables - its in the book.  You then simply need
to assign the channels to the correct drum voice.
This made the dtxpress III exactly like my normal gigging kit - kick,
snare, 4 toms, 2 crashes, a ride, and a china.  I bought all parts
(cymbal/cymbal mounts and tom mounts/pads) from a dtx dealer online.
Re: Adding on..
2005-11-07 by zapaxe
No extra trigger input's??? HUH!?!? You didn't see the 9/10 trigger
inputs? These are split by the use of a stereo type male 'Y'
connector on one end end to 2 mono females on the other end for
instance...Then you plug in two mono pads to the female ends. There
are other ways & cofigurations, that others may be of help, but
that's the basics.
I didn't see if you were adding dual trigger or single trigger
cymbal pads.
I myself went nutty adding extra cymbal & drum pads on my original
DTXpressI kit. I also added rack extentions to accomodate all my
trigger pads. What I also did was buy a DTXpressIII module for a 2-
module set-up. With the 2nd module, I can have extra cymbal & drum
pads all day long. Furthermore, I have 2 single kick trigger pads
with two pedals (one to each module) and a dual Hi-Hat set-up (one
to each module, but controlled by a single Hi-Hat controller pedal,
split by a custome splitter cable I made in which I can have two hi-
hat sounds at one time!
In addition I also bought a 3rd module, an Alesis DM Pro that I've
not yet implemented into my system :O
Steve
2
4
need
kick,
online.
main
Looking at
to
like
