RE: Spam:[DTXpress] How to use my DTXIII w/ my roland drum machine
2006-01-27 by Damon, Rob
If your drum machine has a midi in port, you just need to match the midi note numbers between the two modules. I.e. when you hit the snare pad, if it triggers midi note number 25 in the dtxpress module, when it gets sent to the drum machine it will also trigger the voice/sound that is assigned to midi note number 25. So once you map out which midi note numbers you want to trigger in the drum machine, the you just have to set each of the dtx pads to trigger the corresponding midi note in the dtx module. So if midi note 25 in the drum machine triggers a snare sound, you would set the snare pad on the DTX to trigger midi note 25. OGD
From: DTXpress@yahoogroups.com [mailto:DTXpress@yahoogroups.com] On Behalf Of drums1277 Sent: Thursday, January 26, 2006 6:04 PM To: DTXpress@yahoogroups.com Subject: Spam:[DTXpress] How to use my DTXIII w/ my roland drum machine Is there any way to use the pads or triggers on my Yamaha drum kit to play the drum kits I built on my drum machines? Pretty much I would love to be able to play the kit sounds using my pads instead of my fingers. I hate programing or tapping in the beats. I'd rather build the sound then use the pads to play the beat. I have MIDI cables but no clue how that all works. Ive read but im still like lost? HELP ______________________________________________________________________ The information transmitted herewith is sensitive information intended only for use to the individual or entity to which it is addressed. If the reader of this message is not the intended recipient, you are hereby notified that any review, retransmission, dissemination, distribution, copying or other use of, or taking of any action in reliance upon, this information is strictly prohibited. If you have received this communication in error, please contact the sender and delete the material from your computer. ______________________________________________________________________ This email has been scanned by the MessageLabs Email Security System. For more information please visit http://www.messagelabs.com/email ______________________________________________________________________
