Roland CY-5 as a hihat -- It works!!!
2006-07-06 by geerayman
I just set up a CY-5 with my DTXpress III kit (standard, not the Special). The drum manager at the local Sam Ash was gracious enough to let me take a CY-8 off a Roland floor demo and attach it to a Yamaha demo of my kit to see if I could get it to work. After playing around with it a bit, I found that the output signal wasn't quite as strong as on the Yamaha pads, but I found a setting (trigger type Misc 2 with the gain at 99%) that worked well enough as a starting point. The beat-up CY-8 didn't trigger consistently, but I felt it was worth a shot to order the CY-5, especially at Sam Ash's price ($65 USD). It arrived at the shop in less than a week (I'm in SoCal). I also picked up a Roland MDH-10U hatched tom mount to secure it to and quickly headed home. The pad comes with the hardware to use a tom mount or a cymabal mount, as well as a stereo cable. I started with the same settings I used with the CY-8 at the store and found the same triggering issues, but once I lowered the minimum velocity for the input to 16% and fiddled with the velocity curve a bit, I'm very happy after about an hour's worth of playing with my purchase. It feels world's better to play than a rubber pad, and it's nice to have different bow and edge hihat sounds to play. Oh, and after trying it in one of the cymbal inputs, I found that the choke function works perfectly also! So far, so good, but only time will tell how well it holds up to my novice abuse (technique -- can't I just order some on-line??!?!)...
