--- In DTXpress@yahoogroups.com, "tomnevey" <Thomasnevey@...> wrote:
> I bought a RHH130 Real Feel Hi Hat Pad to go with my DTXpress
> (original). I can't get the dual zone working ... the main body works
> but not the edge! Is there some configuration changes I need to do on
> the DTXpress sound module?
> Be greatful for any help!
I am guessing because I don't have the RHH130 or the original
DTXpress. With the DTXpress II & III you need to set the pad type as
RHH. With the original DTXpress there is no RHH pad type so I guess
you are going to have to try all the others to see what works.
The other possiblity is that you don't you have a voice assigned to
the rim. If you go into voice edit and hit the rim, does it detect
the rim?
Keith.
