--- In DTXpress@yahoogroups.com, "Shane" <smd24_24@...> wrote:
> Can you add pads to a DTXpress II without adding another brain???
Shane,
You can add two single zone pads to inputs 9/10, using a Y splitter
cable (2 mono to one stereo cable).
Other than that, the only other option I know of is the DTXpander
circuit I designed - see the files & pictures sections. That allows
you to use the unused "rim" sounds of existing single zone pads, eg
the toms. There are limitations, such as you cannot hit a pad & its
rim simultaneously, and the rim inputs are not as sensitive as the
main pad, but it can be useful for adding some percussion sounds or
effects.
Keith.
