High hat not working properly - any ideas?
2007-05-18 by lifewayjm
I have a DTXpress kit and the hi-hat controller is not working properly. When the hi-hat cymbal is plugged in it sounds fine. Then when i plug the hi-hat controller in the hi-hat cymbal sounds as if the hi-hat controller is being pushed. If I take the cable out for the hi-hat controller the hi-hat cymbal sounds fine again. I've taken the hi-hat controller to a local drum shop where they plugged it into an existing kit and it worked fine. Does anyone know of a setting in the controller that would make the hi-hat controller do this? Regards, jeff
