has anyone ever gotten the rhh130 to sit level on the hi hat stand?
2007-07-06 by Tom
Just got a rhh130 and will be using it tomorrow... it says to mount it level in relation to the
cymbal support plate, and that it may not function properly if not level... but when you level
it and then tighten it it tilts again... anyone notice this? Am I missing something? I did loosen
the tilt screw on the plate.
I have loaded the rhh130 user manual in pdf on the files section(newly scanned)
Tom
RE: [DTXpress] has anyone ever gotten the rhh130 to sit level on the hi hat stand?
2007-07-06 by Damon, Rob
Tom,
I had a second RHH130 mounted on a remote cable hihat that was tilted at
40 degrees from the vertical and it worked fine.
OGD
From: DTXpress@yahoogroups.com [mailto:DTXpress@yahoogroups.com] On
Behalf Of Tom
... it says to mount it level in relation to the cymbal support plate,
Tom
______________________________________________________________________
The information transmitted herewith is sensitive information intended
only for use to the individual or entity to which it is addressed. If
the reader of this message is not the intended recipient, you are hereby notified that any review, retransmission, dissemination, distribution, copying or other use of, or taking of any action in reliance upon, this information is strictly prohibited. If you have received this communication in error, please contact the sender and delete the material from your computer.
This email has been scanned by the MessageLabs Email Security System.
For more information please visit http://www.messagelabs.com/email
