Three Zone Snare Pad
2007-11-17 by John Spokus
I have a DT Express II that I just picked up used. Of course it has a
single zone snare. I would like to upgrade to one of the three zone
pads, but I'm not sure if the Express II brain supports theses (?)
I know the manual says it supports the multi zone cymbal pads, does the
same hold true for the snare ? Has anybody tried this with a II ?
John
Re: [DTXpress] Three Zone Snare Pad
2007-11-17 by grant
Yes John , it will ,
Cheers
Grant
John
Re: Three Zone Snare Pad
2007-11-18 by Keith
> John
John,
Ipouts 2,6 and 7 are 3 zone, 1,3,4,5 & 8 are dual zone (see P9 of the
manual).
Keith.
2007-11-20 by Jason Stadel
I have a dtexpress 2 and I got a Roland PDX8 Dual-trigger Snare Pad. It is supposed to be 2 zone snare, but for some reason i get snare, rim shot and cross stick out of it. The mesh head is very responsive and it fits well on the set. The only draw back is that you have to hit it pretty hard to get the rimshot. The best part for me was I got use my old snare pad for an extra cymbol.
Cheers
Grant
John
Be a better sports nut! Let your teams follow you with Yahoo Mobile. Try it now.
2007-11-21 by m_rey50
Hi, problem is that PDX8 is a "dual" pad (2 sensors) and DTX has
a "stereo" input (1 pad + 1 or 2 switch). Switches are asocited with
rim and Xstick, and signal provided to the module is diferent from
that from a sensor. That's the reason you need to hit extreme to the
RShot.
On database you can find some ways to "convert" dual's into steroes.
> grant <graant@...> wrote:          Yes John , it will ,
> Cheers
> Grant
it has a
zone
does the
> John
Mobile. Try it now.
2007-11-23 by Keith
> RShot.
or you could use a Y splitter cable & two inputs.
Keith.
2007-11-26 by John Spokus
Man was I being stupid. I didn't realize until today that my DT
Express II already came with a three zone snare pad, which I had a
mono cable hooked up to, thus it was only working as single zone, and
I had the dual zone cymbal pad hooked up as my crash, where I
should've been using it as my ride. Was the manual not clear on this,
or was  I just being stupid ?
--- In DTXpress@yahoogroups.com, "Keith" <keith@...> wrote:
has a
zone
does the
> > John
> John,
> manual).
> Keith.
2007-11-26 by Keith
You can have the dual zone cymbal as a crash.  Somewhere in the manual
I am sure it tells you to use stereo cables for the connections.  On
my DTXpress it isn't a problem because it comes with the stereo cables
all tied onto the rack.  I don't know how the DTXpress II was
supplied, but I guess if you bought it second hand anything could happen.
I'm glad you now have it sorted - I hope you didn't buy a 3 zone pad
to find out you already had one!
Keith.
-"I'm glad you now have it sorted - I hope you didn't buy a 3 zone pad
> to find out you already had one!"
> Keith.
No I didn't, but had one on my Musician's Friend Wishlist, now
deleted.I looked at the manual last night and in the section that
showed the connections, couldn't find any reference to this.
The dual zone cymbal pad is sort of weird though,seems kind of
unpredictable what you are going to get when you hit it. It seems to
respond more to velocity than the area that I'm hitting as far as
which sound it produces. I'll try it as a crash with the stereo cable
and see if I like that better.
Back to the snare, given the fact that the pads are as small as they
are, you have to stay really focused on the area you hit to get the
sound you want, very easy to cross over into the wrong territory.
It's not such a problem when you are doing a basic, snare, hi-hat,
bass beat. But when it comes to going into a roll from the snare to
the rack toms, it's easy to hit the side stick area, which can sound
a little messy.
John
2007-11-26 by Keith
I don't seem to get any subtlety out of the cymbal edge - I whack it
hard and program it as a nice loud cymbal edge sound.  My work on the
DTXpander has shown that some of the insensitivity on the rims of the
two zone pads is due to the module itself, not the pad.
> a little messy.
I must admit I have had a TP100 on a snare stand for a while now, so I
don't find that a problem.
Keith.
2007-11-26 by Nick Falconer
> Keith.
... similar to you Keith, I changed my snare pad out for a TP120 when I
found one cheap in a sale.   I do find it makes the snare much
more "playable", it responds better to dynamics.
Nick
2007-11-29 by John Spokus
-I switched the dual zone cymbal back to crash. It works much better
that way than as a ride. I didn't know you could choke the dual zone
Yamaha cymbals until now.
to
cable
they
hat,
to
sound
> > a little messy.
so I
> Keith.
2008-01-09 by kmwinslow
I was wondering if you could tell me how you set up your dtxpress
(triggers, gain, etc.) to work with the PDX-8. I just bought one to
use with a DTXPRESS I (original orange version), and the rim shot
does not work properly. When I strike the rim, regardless of how
hard, there is no triggering (no sound). If it hit the bottom plastic
of the drum, it does trigger. Everything worked fine with a different
dual-trigger pad, so I know the TRS cable and the sound module are
working. It seems like a sensitivity problem. Any help you can offer
will be greatly appreciated.
Thanks.
--Kevin
> Cheers
> Grant
it has a
> John
Mobile. Try it now.
2008-01-09 by Keith
The best way is to use a Y splitter and use two inputs.  The PDX-8 has
two piezos so can never work well in a single input unless you use the
DTXpander.
Keith.
to
plastic
different
are
offer
has
> DTXpander.
> Keith.
I thought the snare input (as well as a few others) of the DTXpress
was "stereo" (dual-trigger input). In fact, in the sound module, you
can assign a pad and a rim sound for the two triggers for each input.
And the manual says, on page 10, "Trigger Input Jacks are all stereo
input type jacks".  What am I missing?
And what is the DTXpander?
Thanks.
--Kevin
2008-01-09 by Keith
The "stereo" term is a bit misleading.  The problem is that you can
make a pad have two sounds with either two piezos or a single piezo
and a switch.  The Yamaha uses the single piezo & rim switch.  If you
try to use a pad with two piezos the rim piezo produces a signal which
is not what the module is looking for.
It is a circuit I designed - see the files section.  It was originally
designed to allow you to plug two mono pads into a stereo input on the
DTXpress to allow more pads, but it also allows you to put a dual
piezo pad into the DTXpress.
Keith.
2008-01-10 by kmwinslow
DTXpress
you
input.
stereo
you
which
originally
> Keith.
Now it all makes sense. Thanks for your explanation. I'm going to try
plugging the PDX-8 into the 9/10 input and use 9 as the snare pad
sound and 10 as the rim. I then hope to use something like the
DTXpander to use 2 pads to get two sounds out of the #2 (snare)
input. I think this will give me the best of everything --
maintaining the number of pads I have and upgrading my snare. Thanks
again for the help.
--Kevin
2008-01-10 by Keith
> again for the help.
> --Kevin
You could use the splitter and put the main pad through to the normal
snare input & the rim though to 9.  That way the standard kits will
still play the snare without reprogramming them.
Keith.
Re: [DTXpress] Re: Three Zone Snare Pad
2008-01-15 by DARKMOON
Hi Keith,
speaking of snare pad, have you tried using the snare
pad that comes with dtxpress 4 special on a dtxpress 3
special module?
if this is not supported by default, is there
something that i could do to make it work?
thanks.
> as the snare pad
> something like the
> the #2 (snare)
> everything --
> > again for the help.
> > --Kevin
> standard kits will
> Keith.
Looking for last minute shopping deals?
Find them fast with Yahoo! Search.  http://tools.search.yahoo.com/newsearch/category.php?category=shopping
2008-01-15 by Keith
--- In DTXpress@yahoogroups.com, DARKMOON <darkmoon__666@...> wrote:
> Hi Keith,
> special module?
It works fine - I have been using the TP100 for the snare on my
DTXpress III for a couple of years now.  The red knob doesn't do
anything (it does on the DTXpress IV or the DTXtreme) but I like it.
I have it on a snare stand, which I also prefer to having it on the rack.
Keith.
2008-01-15 by Nick Falconer
rack.
> Keith.
Ditto, except I have a TP120 on a stand as I'm such a sloppy player I
like to have a big snare!
Nick
2008-01-16 by DARKMOON
thanks guys. i guess i'll have to start searching for
a good deal now. :-)
keith, the tp100 or tp120 is a triple zone pad, but if
we use it as a tom with a dtxpress 3 special module,
will i get the other 2 sounds? can we configure that
on our dtxpress3 module?
> the snare on my
> knob doesn't do
> having it on the
> rack.
> > Keith.
> a sloppy player I
> Nick
2008-01-16 by Keith
The only 3 zone inputs on the DTXpress 3 are 2, 6 and 7, so if you use
a tom input you will just get 2 zones.  I'm not sure what you would
use a rim sound for on a tom, but it could be anything e.g. a cross
stick or cowbell or percussion sound.
Keith.
