Cymbal Wiring
Cymbal Wiring
2008-10-22 by cbarnhart44
Anyone have a simple schematic (or explain) how a the 130s is wired
with the choke switch?  Thought I might make a couple for fun.
Re: Cymbal Wiring
2008-10-22 by Keith
The piezo goes between the connector tip and sleeve.  The switch
connects between the ring and sleeve.  The third zone is the same but
with a 10k resistor in series with the switch (so both switches
effectively connect to the ring).  The module detects the 10k resistor.
If you are planning to make your own cymbals, you may find some useful
tips here:
http://launch.groups.yahoo.com/group/DIY-edrums/
Keith.
Re: Cymbal Wiring
2008-10-23 by Keith
One other point which you will find out when researching DIY edrums -
people making their own cymbals (or snares/toms) find it tricky to
duplicate the rim switch so often use two piezos to get dual zone
cymbals.  With many modules this causes a problem because you need to
use two inputs to use two piezo signals.  The DTXpander circuit in the
files section here turns two piezo signals into a single piezo signal
plus rim switch so you only need one input.
Keith.
Re: Cymbal Wiring
2008-10-23 by cbarnhart44
Keith,
Thanks for all the replies!  Was curious how the 130S was wired.  From
the pictures it looked like there were 2 seperate ribbon switches but
couldn't reason out why... Curious, does the 10K resistor side control
the choke or the second voice?
Chris
> Keith.
Re: Cymbal Wiring
2008-10-23 by Keith
> Keith,
I am actually thinking of the 3 zone PCY130SC/PCY150S.  I am not sure
if the PCY130S is actually only two zone.  If you see two rim switches
in the pictures just going round the rim, I think they are just
connected together.  The third zone would be the bell.
I don't have the PCY130S but I think the 10k side just does the third
voice (bell).  The main rim switch does the second voice (edge) & choking.
Keith.
