--- In DTXpress@yahoogroups.com, "ali" <bekbydemand@...> wrote:
> I don't know if this is the right place to ask, but does anyone have a copy of the yamaha dtxpress 3 drum module, there is a transistor inside that seems to have overheated and cracked apart, and I would like to know what part it is to order a replacement, and solder it back in.
> Thanks for any answers
> bekim Abazoski
I don't have the schematics, but if you can read the part number I should be able to identify it. Otherwise, if you can show which part it is I can open mine up and see what it is.
My concern would be that the part which is physically damaged may not be the cause. For example, a short circuit capacitor or diode could blow up the regulator.
Keith.
