help....
2002-02-06 by twentytabs
hi all...im about to buy a secondhand DTXPRESS, but i have been told that there a two versions out there, what do i look for to tell whether its a new version or old version...thanx in advance
2002-02-06 by otacon28us
well first thing that i can think of is that it will have the black
drum module(version 2.0) the next thing you would want to look for is
that it will have a support rod that runs across the rack from one
leg to the other,and i believe that the updated version has tp-80
pads,instead of its predecessor the tp-60's,if you search the
archives in this group you will find alot of post especially some
from walt(or my dtxpress tech support as i like to call him (lol)
that describe in pretty good detail what to look for, anyways these
are the things that come to mind in distinguishing the new from the
older version..
hope this helps,
sam(otacon28)
told
> whether its a new version or old version...thanx in advance2002-02-06 by wgardus
also, there is a copy of the brochure for the newer version in the Photos section of this group. It was released last fall so chances are the the used market has the older model, but as Sam and I can tell you, it can be expanded. Walt --- In DTXpress@y..., "otacon28us" <reva@s...> wrote: > well first thing that i can think of is that it will have the black > drum module(version 2.0) the next thing you would want to look for is
> that it will have a support rod that runs across the rack from one > leg to the other,and i believe that the updated version has tp-80 > pads,instead of its predecessor the tp-60's,if you search the > archives in this group you will find alot of post especially some > from walt(or my dtxpress tech support as i like to call him (lol) > that describe in pretty good detail what to look for, anyways these > are the things that come to mind in distinguishing the new from the > older version.. > > hope this helps, > sam(otacon28) > > --- In DTXpress@y..., "twentytabs" <twentytabs@a...> wrote: > > hi all...im about to buy a secondhand DTXPRESS, but i have been > told > > that there a two versions out there, what do i look for to tell > > whether its a new version or old version...thanx in advance
2002-02-06 by okant
The brain is the same in new version (if we're talking about DTXpress) and they're both red. The change is pads and rack. The new pad set is called DTPK9A (old one was DTPK9), and the new rack is called RS60A (versus RS60). DTPK9 ----- 5 x TP60 2 x PCY60 1 x KP60 1 x HH60 DTPK9A ------ 1 x TP80S (dual) 4 x TP60 1 x PCY80S (dual) 1 x PCY60 1 x KP60 1 x HH60 Here is a link: http://www.drumcentral.com/navbar- electronicdrumsets.htm The old version (of DTXpress) and new version (of DTXpress) is priced the same. What Sam mentioned is DTXV2 - that's what I have; it is somewhat higher-end and more expensive than DTXPress and it's discontinued I believe. If you can find it; it's better than DTXpress - but it's NOT DTXpress. Okan --- In DTXpress@y..., "otacon28us" <reva@s...> wrote: > well first thing that i can think of is that it will have the black > drum module(version 2.0) the next thing you would want to look for is
thankyou all very much for the info...its nice to find a group that gives a little help every now & then...cheers -- In DTXpress@y..., "twentytabs" <twentytabs@a...> wrote: > hi all...im about to buy a secondhand DTXPRESS, but i have been told > that there a two versions out there, what do i look for to tell > whether its a new version or old version...thanx in advance
oh boy can it be expanded,but that's yet another story (lol) you just
gotta love monster e-drum kits!!! it brings back memories of the 80's
hairband days where your hair was almost as big as your kit(ha,ha)
good times good times!!!!
later,
sam(otacon28)
black
for
> is
one
these
the > > older version.. > > > > hope this helps, > > sam(otacon28) > > > > --- In DTXpress@y..., "twentytabs" <twentytabs@a...> wrote: > > > hi all...im about to buy a secondhand DTXPRESS, but i have been > > told > > > that there a two versions out there, what do i look for to tell > > > whether its a new version or old version...thanx in advance
