misc tips/suggestions
2002-10-22 by tfkienle
all,
just some ideas based on dtxpress & general edrum experience (your
mileage may vary):
1)regarding an old thread on this board on sticks, I'd highly
recommend nylon tipped sticks & NOT using anything heavy like
marching tom sticks.  The latter will eventually damage the piezos,
break internal solder joints, or knock the piezo from the backing
plate.  I've repaired several pads in the past due to this.
2)alot of the problems i've seen you guys having w/ the midi note
numbers is due to interference from the Universal Map.  Go into the
Utility menu to edit this.  The way I operate, I like to set ALL
midi/drum assignments in the kit, as I don't trigger the dtxpress
from an external source.  I forget right now whether I killed all the
assigments, or mapped everything from 0 to about 16, so that no
future pad assignments would conflict.  I think you can zero it out
to where it says "note assigned in kit" or something like that  (my
drum kits are all midi'd like this:  kick 21, snare 22, closed hh 23,
open hh 24, tom1 25, tom2 26, tom/perc/cym3 27, tom/perc/cym4 28,
tom/perc/cym5 29.  this habit started because emax samplers start on
note 21, & that way I can trigger keyboard voices on the lower
octaves while a keyboardist can play different sounds on the rest of
the board).  anyhoo, this universal map can be a big pain if you like
to customize midi note numbers.
3)ditch the yamaha cymbal pads.  someone has already mentioned using
a tp60 for the ride.  I'd use them for crash too
4)upgrade the kick to an inverted beater.  I have both the S&S & the
pintech ergo kick.
5)this last tip isn't for everyone, but works well for me & may solve
alot of you guys' hihat problems...ditch the pedal & use 2 pads...one
for closed HH & one for open.  depending on how you play, put the
closed more or less in the normal HH position (perhaps a little
lower), then the open HH pad right above & to the right.  this will
take some practice, but the "smearing" together of open & closed is
much more realistic.
again, just some ideas from experience.  number 5 may not be
advisable if you are only using edrums for practice & regularly play
an acoustic kit.  however, whenever I hop on an acoustic (or edrums
w/ pedal) kit, I can still play HH the normal way.
Re: [DTXpress] misc tips/suggestions
2002-10-22 by Jim Tonak
Why nylon tip sticks?  The force of a wooden tip stick hitting the pad
is the same as the force of a nylon tip stick hitting the pad...  I
can see a preference on an acoustic set because the tips sound
differently, but on an electronic kit they sound the same.
I use a TP60 for my ride.  I find the PCY80 and PCY80S fine for
crashes.
>pintech ergo kick.
My KP60 was dropping triggers just like everyone else's when I first
set it up.  Upon some experimentation, I found that a shaped beater (I
use that Pearl Quad Beater) and finding the "sweet spot" of the
trigger pad cured the problem.  It took some fiddling around, but I
found a spot on the pad that would trigger a sound no matter what.  My
KP60 has been trouble free ever since, about a month now.
Something I haven't worked out yet to my satisfaction is how to
route/wrap/secure all the cables in a neat and orderly fashion.  I
hate the look of all those cables just hanging from the rack, drooping
to the floor...I'm talking about where they meet the trigger brain.
What's everyone else doing with all of their cables?
Jim Tonak
ratzo@...
Re: misc tips/suggestions
2002-10-23 by hairytrigger
Regarding the mess of cables: I use a black spiral wrap to bundle the
cables. I start just a few inches out of the module, and wrap all the
way to the end. I put a cable clamp near the end, and screw it to the
module mounting plate to keep everything plugged in. The individual
cables come out of the wrap at different places - in the order they
get hooked up. I need no labeling. everything stays plugged in at the
module. The length of the cable and where it comes out of the wrap
tells me what pad it plugs into!!
Scott
pad
using
> crashes.
> >pintech ergo kick.
(I
My
drooping
> Jim Tonak
> ratzo@t...
RE: [DTXpress] Re: misc tips/suggestions
2002-10-23 by Patricio Murphy
> drooping to the floor...I'm talking about where they meet the trigger
brain.
We're using a 8x8 snake. The one we have comes (I think all of them come
this way) with eight cables of different colours. we had to modify it a bit,
cutting the cover on one end, but it's the best solution we found.
Patricio Murphy
NAN - Buenos Aires, Argentina
http://www.gruponan.com
ICQ 19416686
2002-10-23 by tfkienle
>>>>>>>I should have clarified that point...the nylon is to ease the
head wear/crumbling
> crashes.
>>>>>>>just mentioned it as something to try
the pintech ergo kick.
>>>>>>>again, a suggestion.  also takes up less room & is quicker to
setup.  I play live fairly regularly, so every simplification helps.
drooping
>>>>>>>if you have access to Ikea, go there & buy the cable
management thing they sell.  it is a flexible corrugated plastic tube
w/ a slit down the side, about an inch in diameter.  comes w/ cable
ties & is available in black, white & silver.  similar solutions are
available elsewhere, but i find Ikea to be cheapest.  I think its
around $3.00.  I have 9 trigger cables plus 2 other cables in
mine...looks very cyber/H.R. Giger-ish :)
