Sonar and DTXpress II - instrument definition
2003-03-09 by Stephen Beaumont
After much trial and error, and a lot of frustration, I have managed to get an instrument definition put together for Sonar II. I imagine it will also work in Cakewalk. There are some weird things that happen if you select certain program numbers; the DTXpress brain goes into a loop situation that fills the midi buffer. Therefore do NOT select drumkits that are not named. I have tested the named ones and they all seem to be working, at least in my configuration.
I also send a SysEx message at the beginning of all my Sonar files to the DTXpress that sets it up ready to receive the program changes. This is simply a file that I sent to Sonar from the DTXpress, after I had set up all the parameters in the unit.
Will be interested to know if anyone has been able to improve upon this. I agree that it is amazing that neither Yamaha nor Sonar have come up with any definitions or Studioware.
Stephen
Re: Sonar and DTXpress II - instrument definition
2003-03-09 by wfaraoni
Hello Stephen: nice work, you obviously have a much better handle on
this than I do. I spent a couple of hours today trying to get a drum
map to work only to find out that you loose soundfont capability if
you use a drum map. its one or the other!
 Now I have to ask you the particulars of getting it to work because
the snare and kick are still out of wack for me even though I can
emulate and record the rest of the sounds just like on the dtx. at
least the toms and cymbals sound like what there supposed to instead
of horns and whistles !!
what I did was load your instrument definition file to channel 10 of
synth b of my audigy. which I used for output.
then I went into utility mode on the dtx and went to the dump page
and dumped the system file to the bank 10 of the sysx interface in
sonar. then I tried the user map instead.then I tried all the files.
I can select the various kits fine and the 4 I tested seemed to have
that same incompatability.
I am using a creative audigy card, so I ran it on synth b or should
I load it to a drum map?
anyway if you could provide a "step by step" for Dummies, You will
be our hero of the year :)
this is definitely much closer than anything Ive been able to do.
I tried a bunch of other stuff but its not worth going into all of
that because none of it worked.
Your efforts are GREATLY appreciated :)
Thanks Bill
configuration.
> Stephen
2003-03-09 by stev1ebb
Glad this is working to some extent for you Bill. I am no expert -
just hate being defeated by things like this and as my purchase of
the DTXpress was mainly for recoding in Sonar, I had to get it
working somehow!
Anyway, this is what I do. First check that the DTX is associated
with the midi output and channel 10 in the "define instruments"
section. I use a Roland UA-100 Audio Canvas which has two midi
ports. I have my synth associated with the 16 channels of MIDI 1 and
have assigned all of MIDI 2 to the DTXpress. If you only have one
midi port, then you would assign channel 10 to the DTX and
everything else to your other midi gear.
Then in track view, I set "IN" to "MIDI OMNI", "OUT" to the midi
port I am using (in my case 2). I set the "CH" to channel 10 (which
then shows "DTXpress") and "BNK" to "BANK" (NOT to GM - I think this
is important as otherwise you will get GM sounds when you strike a
pad). I select the drum kit I want by clicking the "PCH" arrow and
all the drumkits show up.
I am getting all the sounds (including the kick and snare) to sound
and I can change them during playback (and when the sequence is not
running) without any problem. I don't think the drum kits with midi
sequences work in this but I never use them so for me it is not an
issue. Perhaps somewone can let us know how that can be achieved.
You do have to ensure that the track is "in focus" when you record
the drums, or you will get other instruments "showing through" the
sound. Also, I have only managed to achieve success with the input
set to MIDI OMNI.
I know there is a way to associate particular program change numbers
with particular kits within the DTXpress, but the instrument
definition I attached on my last post seems to do the trick, at
least for what I want it to do.
I hope that these pointers work for you. I am not familiar with the
Audigy Card and have not played around with drum maps, but with
luck, these settings should give you what you are looking to achieve
which is really just being able to select kits from the computer,
record them and play them back in the mix. Life should not be this
complicated! I am just glad I have it working to a level that suits
my needs.
Updates and more info would be great. Anyone played around with
Studioware yet?
Good luck Bill with this....let me know how you make out :)
Stephen
on
drum
if
because
instead
of
files.
have
should
> Thanks Bill
I
> configuration.
files
upon
have
> > Stephen
Stephen; thanks for the reply, I am doing all the same things you
are with regard to the instrument definition file. So the problem
must be with the Sysex portion. heres is what I am doing for that.
 I open the sysx in Sonar from the view panel.
I highlight bank 10 then hit the red arrow.
I select You start dump on instrument.
At the Dtxpress I go into utility > midi bulk dump > fmt =
at that point I've tried, user map- or--system data  -or-  all data
there
.. depending on which one you choose the amount , in bytes varies.
which one are you using.. are you using bank 10 there?
after that I hit done.
I am very frustrated as well! I just bought this thing for the same
reasons as you and Ive spent about 7 hours trying to get this
feature to work. By the way, if you visit nowhereradio.com and
search wfaraoni, Ive posted some singles I'm working on up there and
one of my biggest problems has been getting a decent drum track. Are
you posting anything of yours?
Have a great day
Bill
> working somehow!
and
(which
this
sound
not
midi
> set to MIDI OMNI.
numbers
achieve
suits
> my needs.
> Studioware yet?
> Stephen
handle
> on
> drum
> if
> because
can
at
> instead
10
> of
page
in
> files.
> have
> should
will
of
> > Thanks Bill
II.
> I
things
tested
> > configuration.
> files
> upon
> have
> > > Stephen
