Hey, Stewart,
What about selling it and using the return to buy a couple of
new/used 8" or 10" pads? Just a thought. That way you wouldn't risk
losing everything if you dismantled it for parts. Since the 55 has
MIDI in/out, the triggers would seem to be compatible with the DTXII
module as is. If you pry the individual pads from their housing,
however, they won't have any visible means of support for mounting
on the rack, and you'll undoubtedly have to adapt the wiring to the
new situation. A few people on the board--Scott (hairytrigger) for
one--have strong DIY skills and might be able to help.
The 55 does have a dedicated stand. You could mount it on the stand
and connect it via MIDI to access the DTX sounds, as you would, say,
the Hart Multipad or the DrumKat. As such it would be hard to use as
a snare, tom, or cymbal set, but it could be used as tuned/untuned
percussion, effects, increment/decrement etc. What do you think?
Ed
--- In DTXpress@yahoogroups.com, "moosetication"
<moosetication@y...> wrote:
> Anyone know much of the innards of the Yamaha DD-55 toy (the
silver
> thing with 4x5" and 3x3" pads)? Since I have one of these and
given
> that it's MIDI-enabled, I am eyeing it for some surgery to use in
> conjunction with the DTXP2. . It's too big as it stands to mount
on
> or near my kit (and looks a bit Flash Gordon to boot), but I am
> minded to take it apart to see if (a) I can mount the triggers
> and "brain" separately and give myself seven additional pads
> reasonably cheaply, and (b) if the pads actually use piezos or
FSRs,
> see if I can trigger the "brain" with external pads.
> Clues, anyone?
> Stewart
