Those damn PCY's
Those damn PCY's
2003-05-15 by Darren Lo
I've been having problems with the response of my PCY60's, which I've
never really been happy with. At first I was having a tremendous problem
with missed hits, and spent a lot of time jiggering the mounts and fiddling
with the rejection settings, to no avail. Finally, I looked at the circuit
boards and discovered cracks in the solder on all four solder points for
the input jacks on both cymbals. Resoldering those points seems to have
cured the missed hits problem.
However, it has done nothing to solve my other problem, which is erratic
volume response. If I take a TP80 and play a steady beat, I can keep the
trigger levels fairly consistent, e.g.: 61%, 65%, 63%, etc. If I try to do
the same thing with the PCY60, the results can vary anywhere from 99% to
20%, with no apparent rhyme or reason. Even a really good thwack can
sometimes register only at about 20%. This happens whether I'm playing
8th notes at 180 or quarter notes at 60. Let me note that I already try to
play solely on top of the Yamaha logo since anywhere else seems even more
unreliable.
Any thoughts on the cause of this? Bad soldering job, bad mounting job,
bad technique, dead PCYs?
Darren Lo
lo@...
Re: Those damn PCY's
2003-05-15 by liberatusvirus
Darren,
It might be bad soldering. I had a drum that misbehaved like that; I
resoldered everything without any luck. It's unlikely to be poor
technique or mounting, though hitting too hard for a long time can
result in problems with the pad not unlike what you're experiencing.
And if these are PCY60s, they've probably been around for a while.
But I'd vote for something interfering with the signal, like a
hairline crack in the solder, or even dirt on contacts. Have you
tried the simple spraying of WD-40 on the jack and wiggling it
around a bit at the outout?
Ed
I've
problem
fiddling
circuit
points for
have
erratic
keep the
try to do
99% to
can
playing
already try to
even more
> unreliable.
job,
> Darren Lo
> lo@m...
2003-05-17 by zapaxe
I don't have anything to help here. But in relation to where's the
best place to hit the cymbal pad, I agree that hitting on the logo
seems to be the most reliable spot! I get silent hits often. I go
for the crash and....Egg all over my face!
I've not had a solder joint come loose, but the cymbals from day one
have been problematic. The 1/4" jack on both my cymbals on my
DTXpress (#1) have had bad contact & I've had to either push them in
a little further or back them out a bit! Funny that the pads have
not had this happen?
As for cracks, I'd imagine you'd have to hit them very hard. Since I
don't have the experience in the responsivness of an acoustic set, I
see that this e-drum can only be hit so hard for an effective
response.
Steve
I've
problem
fiddling
circuit
points for
have
erratic
keep the
try to do
99% to
can
playing
already try to
even more
> unreliable.
job,
> Darren Lo
> lo@m...
Re: [DTXpress] Re: Those damn PCY's
2003-05-26 by Vincent Emery
Like you, I had this problem of silence when hitting the PCYS. the solution is simply "how" you hit it. You must remove the stick as quickly as you hit it and you will have no problem. Hit "dynamically", that's all !
Sent: Saturday, May 17, 2003 5:50 AM
Subject: [DTXpress] Re: Those damn PCY's
response.
Steve
I've
problem
fiddling
circuit
points for
have
erratic
keep the
try to do
99% to
can
playing
already try to
even more
> unreliable.
job,
> Darren Lo
> lo@m...
Community email addresses:
Post message: DTXpress@onelist.com
Subscribe: DTXpress-subscribe@onelist.com
Unsubscribe: DTXpress-unsubscribe@onelist.com
List owner: DTXpress-owner@onelist.com
Shortcut URL to this page:
http://www.onelist.com/community/DTXpress
2003-05-27 by zapaxe
Huh,
Intersting Vince, I'll try that! I guess maybe I lay into in too
much.
Another weird thing is the kick drum pad misses a beat sometimes
also. But that time I was aware of how I was kick'n it! I ordered
new kick trigger's, but it hasn't happend in a while.
Thank's, Steve
--- In DTXpress@yahoogroups.com, "Vincent Emery"
>   ----- Original Message -----
>   From: zapaxe
>   To: DTXpress@yahoogroups.com
logo
go
one
them in
have
Since I
set, I
>   response.
>   Steve
which
>   I've
tremendous
>   problem
and
>   fiddling
>   circuit
>   points for
seems to
>   have
is
>   erratic
can
>   keep the
I
>   try to do
from
>   99% to
thwack
>   can
>   playing
>   already try to
seems
>   even more
>   > unreliable.
mounting
>   job,
>   > Darren Lo
>   > lo@m...
>         Yahoo! Groups Sponsor
Service.
