rim shot and cross stick
2003-08-10 by apolt.rm
I am slightly experienced drummmer but not so knowledgeable on
electronics and the DTX v.2 which I bought recently. My main problem
is about rim shot and cross stick sounds. I can not take them off
from the set any longer. Every part of tp65s responses in the same
way like I hit in the middle of it. I have not done anything on the
original set up and it's been working fine since I bought it - 2
months- except this newly appeared problem. What do all guys think
about that? Could something be damaged in it?
Gökhan
* I only came across to the message below and tried to apply
instructions and failed as there is no response on the rim.
The snare needs a stereo cable.
The trigger needs to be set to a TP65-1 (the TP65 is for the single
zone
pads, the TP65-1 is for the three zone pad.)
When you go into edit voice, tap the center of the pad, menu should
say
"snare", when you tap one side of the rim the menu should say "snare-
r1"
(rim 1) and when you tap the other side rim, the menu should
say "snare r2"
(rim 2). Once you get those to appear on the menu, just scroll down
and
select the voice you like. For example:
snare = S\001 loosy (the pad sound) ; snare r1= S\002 LoosyRim (the
rim
shot); snare r2= S\109 s sstck1 (cross stick)
Re: rim shot and cross stick
2003-08-10 by liberatusvirus
--- In DTXpress@yahoogroups.com, "apolt.rm" <tendencies@s...> wrote:
> Hi,
problem
> Regards
> Gökhan
> zone
> say
say "snare-
> r1"
> say "snare r2"
> and
> rim
Hello Gorkhan,
I assume that (1) you mean DTXpressII--not DTXv2.0, which is an
older, discontinued model; (3) that your cable is stereo; (4) that
the pad is set in the trigger menu, as stipulated above, for the
three-triggered snare; (4) and that you know how to view the correct
information in your voice menu when you hit and program the rims. If
you are getting rim information in the voice menu when you hit the
rims, check to make sure that gain is registering in the snare's
trigger menu when you hit them (a number from 1 to 99). If the rims
show voices when you hit them, and they have gain, but no do not make
noises different from the pad's center, then something may be amiss
in the module's signal path. Try a factory reset (you'll lose all
your user kits if you don't store them elsewhere first), and program
the rims again. Make sure that their volume is high enough to
register and that they aren't the same voice as the body of the pad
(snare). If the module still won't work, call Yamaha.
If you can't call up the rims in the voice menu by hitting them, try
another stereo cable to make sure that the first one isn't the
problem. If that doesn't work, you should get in touch with Yamaha.
FSRs, which are the rim triggers, do wear out, but not after a few
months. You should be able to get a new TP65S.
Ed
RE: [DTXpress] Re: rim shot and cross stick
2003-08-11 by rdamon@mckinney-usa.com
> Ed wrote: "If you can't call up the rims in the voice menu by hitting
> them, try
> months. You should be able to get a new TP65S."
> Another suggestion:
> The TP65s can be plugged into any of the three 3-zone inputs for testing
> purposes, (2,6,7). Plug the pad into zone 6 or 7 and change the pad input
> type in setup menu and the voices. Instead of rim1/rim2 you'll set up
> cup=rim1, edge=rim2. If the pad does work, then it may be a bad pad. If it
> works, then some setting in the module may be bad.
> OGD
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> click here
> <http://rd.yahoo.com/M=251812.3170658.4537139.1261774/D=egroupweb/S=170503
> 1972:HM/A=1693352/R=0/SIG=11tralmvc/*http://www.netflix.com/Default?mqso=6
> 0178293&partid=3170658>
> <http://us.adserver.yahoo.com/l?M=251812.3170658.4537139.1261774/D=egroupm
> ail/S=:HM/A=1693352/rand=901804899>
> Community email addresses:
>   Post message: DTXpress@yahoogroups.com
>   Subscribe:    DTXpress-subscribe@yahoogroups.com
>   Unsubscribe:  DTXpress-unsubscribe@yahoogroups.com
>   List owner:   DTXpress-owner@yahoogroups.com
> Shortcut URL to this page:
>   <http://groups.yahoo.com/group/DTXpress>
> Alternate DTXpress site:
>   <http://www.dtxpressions.com>
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> <http://docs.yahoo.com/info/terms/>.
> ________________________________________________________________________
> This email has been scanned for all viruses by the MessageLabs Email
> Security System. For more information on a proactive email security
> service working around the clock, around the globe, visit
> <http://www.messagelabs.com>
The information transmitted herewith is sensitive information intended only
for use to the individual or entity to which it is addressed. If the reader
of this message is not the intended recipient, you are hereby notified that
any review, retransmission, dissemination, distribution, copying or other
use of, or taking of any action in reliance upon, this information is
strictly prohibited. If you have received this communication in error,
please contact the sender and delete the material from your computer.
> Gokhan wrote:"Just a shot in the dark. Have you recently had your pads off
> the rack,
> and then replaced them. I don't know if the 65s is visibly different
> from the rest. Perhaps you got the wrong one there? stranger things
> have happened (to me)."
> The rubber rim on the TP65S has a groove in it where the rim switches
> are.The TP65 does not have a groove around the edge.
> OGD
