Replaced Kick Trigger on 'original' DTXpress 1, now...
2003-08-24 by zapaxe
Hello, Now the A/B switch (I can swear) is reversed! As I sit at the set, I reached over behind the kick and swithed it to the left to make less louder. Now it's the opposite...? I changed the kick trigger because it was skipping some hits here & there. I bought them from a Yamaha dealer of parts. I was directed to them by Musician's Friend (Where I bought the kit from). Now I seem to be skipping kick hits less often, but I'm STILL mis- triggering! Before I changed the trigger (which was a little bit thicker than the original...?)I thought I might have an A/B switch problem on my kick controller. I thought this because whenever I reached down to hold the A/B switch, I had less mis-triggering. But the I thought it may be by chance. So since I had two new spare kick triggers I'd give this a try. Now I'll have to try & replace my A/B switch to see if mis- triggering can be totally eliminated. Anyone else have these problems with either bad triggering or A/B swith gone bad due to vibrations? I was thinking about installing a new A/B swith remotely located from the kick to avoid future vibration problems. Thanks, Steve
