Help
Help
2003-10-24 by Christopher
I need help.  I recently purchased the DTxpress 2.  The amp that I
purchased is garbage.  What is the best amp to use for live
performance?  Also, how can I connect to my laptop Compaq computer?
Where can I find the cable? I am having problems.
Re: Help
2003-10-24 by liberatusvirus
--- In DTXpress@yahoogroups.com, "Christopher"
computer?
Hi Orlando,
What kind of amp did you buy, and where do you play live? So far as
connecting your DTXpress to a laptop is concerned, you'll need an
external MIDI interface, one of the MIDIman units being the obvious
choice. You can either make the connection via the laptop's printer
port or via USB. The device will come with the appropriate software
drive and, hopefully, the cable to the computer. You'll have to buy
your own MIDI cables. Any brick and mortar music store worth its
salt, like Guitar Center, or even some office supply stores will have
what you need, as will just about any music webstore like Musicians
Friend, zzounds,etc. Give us a little more info, and we'll give you
some suggestions.
Ed
Re: Help
The amp I purchased is a Fender 150 Watts.
--- In DTXpress@yahoogroups.com, "liberatusvirus"
I
> computer?
> Hi Orlando,
have
> some suggestions.
> Ed
Re: Help
2003-10-24 by ralphpegden1
Regarding, live performance,  probably the best system available for
small gigs and monitoring  is the Roland PM-3  very good quality,
stereo sound but somewhat expensive(circa $700) also ideal for using
at home at low volumes. But if you need power then you will need a
high quality/high output Keyboard amp or run it through a full range
PA (i.e. You will need excellent Bass and High end response to get an
accurate drum sound).   I have only recently got my DTXpressII and
want to try it at our next gig  (Nov 3rd) so I am going for the PM-3
and lining that out through the PA if its required. But I must stress
that our band isn't that loud and we have a great PA. The PM-3
wouldn't be suitable on its own for a large gig.
regards.Ralph
computer?
Re: Help
The Fender, I assume, is a guitar amp, which wouldn't be ideal for
the DTXpress. As Ralph says, a keyboard amp is far more suitable
because it can do justice to the wide frequency response of an e-drum
kit. The Roland PM-3 is a good option for practice and small
(emphasis on small) venues, but any setting remotely large and
crowded will require a PA. Yamaha is poised to offer two e-drum
monitoring systems of its own, on the order of the PM-3, next month--
a $300 satellite/ subwoofer combo and a $600 satellite/subwoofer
combo. If you can avoid Roland prices, you'll be doing yourself a big
favor. If you want more detailed suggestions, clear some time and run
a search of this site's archives under "amp." Ultimately, you want to
get the largest woofer or subwoofer (preferably 12" or 15") and the
most power that your wallet can afford; pushing more air requires
more power--and not just to play loudly. A big amp with the
appropriate power supply to drive it will also sound better when
played at less-than-ear-shattering levels. Your ears will love you
for it. But don't be discouraged if you can't break the bank. Despite
the sonic compromises, a 10" woofer and modest power may be perfectly
acceptable for home and live monitoring. Personally, I'm willing to
bet the impending Yamahas will be winners.
Ed
Re: Help
2003-10-24 by moosetication
--- Christopher wrote:
> I need help...
I really have gotta pull my finger out with this document...
B-(
Stewart
Help
2007-04-30 by Steve Schaefer
I keep sending post and they are never to be see again. What going on?
Re: Help
2007-04-30 by Keith
Steve,
I can see one attempted post by you logged as "Bounced message: Not a
member".  I am not sure what this means - hopefully one of the other
moderators will chip in with an explanation.  My guess is that it was
to do with the yahoo email address you used to try to send a message,
which  you have now changed.  However, this message has got through
and so hopefully the problem is sorted.  You may find a delay in them
appearing because the first few posts of a new member are moderated to
keep out the spammmers.
Keith (trainee moderator).
Re: [DTXpress] Re: Help
Thanks Keith Can you send me those Bounced messages so I can re-post them? ... -- Steve Schaefer Those who give up liberty for the sake of security deserve
Re: Help
2007-04-30 by Keith
> Thanks Keith
> Can you send me those "Bounced messages" so I can re-post them?
Steve,
All I can see is a log telling me it has been bounced - not the actual
message.  If you sent it via an email program you may have a copy in
your SENT folder.
Keith.
