--- In DTXpress@yahoogroups.com, "JAYMZ" <jaymz_hughes@y...> wrote:
> OK... I figured out how to do a factory reset , but that did not
> help.... it still sounds really low volume, and the bass drum is
> barely there, even when the volume knob is cranked , and still
sounds
> like a weird reverb setting yet i tried to change that too... to no
> verb , but still sounds like im in a tunnel i hope i did not spend
2
> grand for this thing to poop out on me not even 2 mos after getting
> it. i still dont even know wht happened , as i saud before , i was
> fine , i took a break come back hit them and poop...dag blurnit.
> thanks for your time ... Jaymz Hughes
Jaymz,
Let me ask a couple of easy questions: Have you shut the module off
for a minute or so and turned it on again? Whether you're listening
through headphones or an amp, have you checked the cable connections?
If am amp, is the phenomenon duplicated through phones, and vice
versa? Do you have another power supply that you can swap for the one
that you're using--a universal that you can set exactly to the
Yammie's specs (12V; I don't remember the tip mV or polarity)? It's
extremely rare that one of these things should go south on you so
soon, if ever, but it's possible.
Ed
