Yamaha amps
Yamaha amps
2003-12-08 by slushycow
As I always blab about, the DTXpress was released her in Japan and
seems cool. In the catelogue, there are also two amps that are custom
made for the DTXpress. Has anyone heard of these? (I'll post the
model numbers when I get home) Have they been available in the past?
These days, I'm looking into amps and there are many choices. I just
read the post about the Behringer amps. They sound nice too. I'm sure
it's been discussed to death, but what do you look for in an amp for
e drums? Keyboard amps? These Yamaha's will cost a lot for me here in
Japan. Everything does.
Jon in Japan
Re: [DTXpress] Yamaha amps
2003-12-08 by Stephanie Ellison
Yes, I usually go for keyboard amps, as they play the whole range of
frequencies that an e-drum set will play.  Bass amps won't do much for high
end, and guitar amps are too limited.
Stephanie
Re: Yamaha amps
2003-12-08 by emf
custom
past?
Hi Jon,
Yeah, we've seen them advertised--a 50 watt and a 100 watt model, for
about $300 and $600, respectively. They appear to be Yamaha's swipe
at Roland's PM-3, but at a more reasonable price (at least here).
December is apparently the official month of their release (just in
time for Christmas). If they behave like the PM-3--with these
specs,the prospect is likely--they will be great for small practices
and stage monitoring, but they won't work as primary stage
amplification for any but the most modest gigs.
What I bet would work well for your band (jazz, right?) would be a
configuration of the new remote-controlled Bose Personal Aplification
System, each unit consisting of cylindrical speaker with a base
housing its electronics and one or two separate bass modules. They
are intended to replace the need for separate monitors, PAs, and
mixers, allowing musicians to hear the same sounds as the audience.
The price isn't cheap, but considering the convenience, it's not
unreasonable. It's out in the States, though in limited supply, and
not expected to have a European or Asian release for some time. One
of the designers has offered me a crack at it, thinking that it may
be particularly good for e-drummers. I can't wait for the
opportunity, but I have no idea when a review unit will shake out
(end of shameless, but sincere, plug for friend).
In the meantime, as Stephanie says, keyboard amps make the best e-
drum monitors. But the JBL Eons are popular, too, if you have the
green.
Ed
